Old 03-24-2012, 02:12 PM   #1
junior 50
key locked in on position
cant turn off motor had to stall it.Do i got to remove whole colunm or maybe streering wheel and go from there
junior 50 is offline   Reply With Quote
Old 03-24-2012, 03:53 PM   #2
Mikec10
Mikec10's Avatar
Re: key locked in on position
Do you have an auto column? i have an auto column and i swapped in a manual transmission while still having the auto column, you have to make sure it stays in park, try wiggling the column around, i had that happen to me once.
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 03-24-2012, 05:08 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
you can first go under the column and pop out the linkage to the ignition switch and make sure the truck is totally off then disassemble to replace the switch if its the switch thats bad..
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-24-2012, 05:17 PM   #4
jhngardner367
jhngardner367's Avatar
I would first,lift up on the gear selector lever,and try to move the key.It may have simply slipped out of adjustment.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
