03-24-2012, 08:28 PM | #1 |
I need opinions be nice lol
Ok as you can see im kind of doing a rat rod theme I guess!!! Im not thrilled with the stance Im thinking maybe the back maybe to high Im not a hundred percebt sure. I did 2 drops in the front and 3 iin the back. Is there a way to lower the spring I have now in stead of buying new ones?
03-24-2012, 08:46 PM | #2 |
Re: I need opinions be nice lol
Personally I like the rake. But it's an unpopular look for this forum.
'66 C10 250 3-on-the-tree '68 Galaxie 460/C6 '74 914 2.0 |
03-24-2012, 08:58 PM | #3 |
put a 2'' block underneath your axel...2x2 steel or even 2x3...but dont exceed that with a block..that will flatten it out a bunch and still have a little nose bleed...............ive messed with that style trailing arm set up a bunch lowering....finally 4 me i found 6'' drop coils adjustable pan-hard bar and ran a 3''block....and its low...frame is notched and my pumkin is a couple inches from my bed
03-24-2012, 08:59 PM | #4 | |
03-25-2012, 03:00 AM | #5 |
There are a bunch of us out here that like hillclimers...we like 'em a lot.
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
03-24-2012, 09:14 PM | #6 |
Senior Enthusiast
I share the same opinion as rendus, but should you decide to go with blocks and want to save some money, here’s a thread that may prove helpful:
http://67-72chevytrucks.com/vboard/s...d.php?t=196457 Nice looking truck!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
03-24-2012, 09:21 PM | #7 | |
But Found Her 25yrs Later!
03-24-2012, 10:00 PM | #8 |
I like it. I always thought the back should be a tad bit higher then the front.
03-24-2012, 10:00 PM | #9 |
rake?.... did someone say rake?.. i have a little rake on mine also!
the Stealth Weapons 63 project, all comments, advice, and critiques welcome! http://67-72chevytrucks.com/vboard/s...d.php?t=438235 |
03-25-2012, 02:59 PM | #10 |
Me like that...
Ken B 60 Chevy Apache 2019 Chevy Silverado Z71 Why buy something when you can build it for twice the price.. Just because something can be done doesn't mean it should be done... |
03-24-2012, 10:22 PM | #11 |
Looks good to me. Where did you buy the wheels?
03-24-2012, 10:23 PM | #12 |
Looks good to me!!
Opportunity usually comes disguised....As hard work!!! |
03-24-2012, 11:21 PM | #13 |
SRVBLUES64,
I noticed you started this thread some time back: http://67-72chevytrucks.com/vboard/s...d.php?t=446443 And now it appears you found some nice seats. What did you decide on? Can we see some more pics?
03-25-2012, 12:42 AM | #14 |
60-66 Nut
I agree.....I see nothing wrong with the stance.
Did you ever get that power steering pump mounted?
03-25-2012, 01:07 AM | #15 |
You can buy blocks in 1/2" increments from 1/2" to 2" from CPP and others I'm sure. That way you can decide your ride height.
http://www.classicperform.com/Store/...Truck/CP45.htm
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
03-25-2012, 03:07 AM | #16 |
Stance is nice...tha negative camber should make it fun in tha rain..lol
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
03-25-2012, 03:21 AM | #17 |
Resistance is Futile
I think the rake is fine. In the past I've had trucks with a rake like that and I found they just had too much weight in the front ('75) to be comfortable over bumps. They rode better when I leveled them out a bit. My '66 has quite a rake and I like it.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-25-2012, 04:00 AM | #18 |
Ilike the way it sits now its a truck dont go any lower a load will take care of the rest
03-25-2012, 06:13 AM | #19 |
Whats a RAT ROD theme? I always heard a rat rod was a unsafe POS....yours doesent appear to be unsafe
03-25-2012, 09:27 AM | #20 |
I like the Rake Also
GreshamP1GLET |
03-25-2012, 10:23 AM | #21 |
Rake? I'm still trying to figure out what rodent genitalia has to do with old trucks..
03-25-2012, 12:57 PM | #22 |
Drive it like that for awhile and if you decide you still want to go lower, 1" block at a time. I think 2" might be too much, but I like it as is.
Btw, your bed wood is looking good! What did you use on it and did you seal the underside? I like the wheel choice too |
03-25-2012, 02:58 PM | #23 |
Looks good to me too...
