Hi guys am new to this web sight and joined it because of the thread I seen on home made lift. I currently am building a sub frame lowering leaf spring mounts on my 79 blazer. I an also relocating the front shackle to the front of my blazer. My big question is how do you calculate where the front mount should be as i have seen they are never strait at each other and how long should my shackles be. I will also be running longer leaf springs and possible moving my front axle forward.This is my first big strictly off road truck. All others have been street legal and i installed manufactured lifts running 33- 37s I was wondering what gears you would run. It will be a trail rig and mud racer. I am running stock 350 welded Dana 60 and welded 14 bolt I am running 42 inch fire stone vtreads that are 11 inches wide. There max spread is 55 mph. So any advice any one can give me would help. Thanks guys
Posted via Mobile Device |
Re: Shackle placement and length
Welcome to the site! The 52" spring swap is common on the front and diy4x.com has a good kit. Also off road design makes a zero rate add-a-leaf that allows you to move the axle forward or back a bit. Why are you moving the shackle to the front? Most of the swaps I have seen move from the front to the rear.
Gears are more dependant on your motor. I have a buddy who has a mud drag truck. He runs 4.56 gears with 39.5 boggers, but his motor is a 406 small block ~600 horse and he goes through the lights at about 7000 rpm, so obviously a little different. He runs low range in his t-case and I think gets into 3rd gear on his TH350. Anyways, post up some pics and guys will surely help you out on here.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
Ok thank for the advice. I am moving the shackle to the front of my leaf on my front leaf to angle my dif and I will be posting pics when I have time. I was wonder if there was a formula to the bracket placement and shackle length because i will be lowering my mount and moving them. I have seen those kits on the net but I will lower leaf spring mounts and it will be Easyer and stronger for me to build them for my self
I would leave the swing shackle at the rear of the spring. GM put them there for a reason, a front axle should rock back when hitting something then pop forward. If you you move the swing shackle to the front then the suspension will be working against it's self. If you are running 42" tires you will want nothing higher than 5.13 gears.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
If you do a Google search on leaf spring suspension design, or building a leaf spring suspension you will find a lot of helpful information on shackled location. It's what I do when I have questions on my 4x4 conversion.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
Ok thank you that's the best info so far
The way we do it is to go ahead & put the springs you're wanting to run on the axel. Then roll it all up under the truck to find where the front mount needs to be to keep the axel centered in the wheelwell. Find the amount of rear shackle length you need by using some 2x4s or such to slowly & easily lower the truck's full weight down onto the springs then measure length from springs eyes to the frame mounting point. This may take several times of adding blocks & measuring to get it like you want. A friend with a big tractor to lift the front of the truck up & down is very handy & much safer than fooling with jacks. Just be careful & use jack stands!!!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#8 | |
#9 | |
Still plays with trucks
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
