"the other guy"
HELP! rebuilt 700r4 pressere check numbers inside
gear- press@idle w/tv - press@idle w/o tv - press@hi idle full tv
(Park)- 75 - 125- 110 (reverse)- 120 -200 - 175 (neut) -75 -125 -110 (OD) - 75 -125 - 110 (3) -75 - 125 -125 (2) -175 -175 - 175 (1) - 110- 110 -150 here is my problem so far, 1-2 shift is about right. engine rpm flares a bit between 2-3 and i think 4th is ok, been scared to drive it far enough to really find out. and suggestions from any pros? thanks -art
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
Re: HELP! rebuilt 700r4 pressere check numbers inside
I think you need to re-do your chart, I dont see it gaining 50psi with the cable unhooked.
"the other guy"
i double checked my numbers, they are spot on? im not sure whats going on here?
If I ignore the "cable unhooked pressures" The Full Pull pressures are low for a good fresh 700R4, A worn one will have pressures about like that.
A "flaring" 2-3 shift is a death sentance to the 3-4 clutches, Even if it only happened a couple times...The 3-4s are most likely burnt. On a 700R4 there is a long list of problems with the 3-4 clutches. If I would have built your unit, I would be pulling it out & going through it again! |
"the other guy"
i installed a corvette servo from a local trans shop, took 30 mins. now the trans shifts good and firm. during my pressure tests, i do believe i may have made a mistake in the procedure. clinebarger, do you know why this solved my problem? thanks -art
#6 | |
2nd gear.....The 2-4 band applies. 3rd gear......The 2-4 band releases and the 3-4 clutch applies. The "Corvette" servo helped you because it has greater surface area, so more oil flows to engage and disengage it. This makes it slower, so the 2-4 band takes longer to pull off and it matched up better with the application of YOUR 3-4 clutches. It also engages slower, Causing a later 1-2 shift. Any length of time between the 2-4 band disengaging & the 3-4 clutches engaging will cause a flare. Your 3-4 clutches could still be burnt or the clutch clearances were set loose during the rebuild, And your "fix" with the 2nd piston is just "masking" the problem. I like to match the 1-2 accumulator valve spring to the 2nd piston, Transgo shift kits have all provisions to do this. |
listen to cline barger hes right i also build and agree with what hes saying
"the other guy"
im not disagreeing, my trans knowledge is comparable to a 1st grader. so is my trans ok? or am i being a little too "glass half full"? it really sucks because the guys that assembled my trans are long gone, its been over three years. and the instructor,a great guy, has been retired for 2 years now. so i cant really get any info. all i know at this point is that i payed for a transstar rebuild kit, and a transgo shift kit that cost around 120. no labor charge. i guess ill just drive it easy untill i can afford a good rebuild.
#9 | |
