Old 05-06-2003, 11:12 AM   #1
special70gmc
special70gmc's Avatar
c-20
does anybody know of a parts supplyer that sells leaf spring bushings for my c-20 as well as u bolts from a 67-72 ford i think crazy L said thats what i need there actually u shaped. i tried local places but they looked at me like i had 5 heads and probly didnt even know wat a bushing looks like. thanks every body -kyle
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 05-06-2003, 11:25 AM   #2
crazy longhorn
Fabricate till you "puke"
You can have the U bolts made at a local spring shop, & might try them on the bushings also. The pcs I used from the Ford truck ,were ther plates that the U bolts pass through(junk yard item). Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-06-2003, 02:47 PM   #3
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Don't laugh.......JCWhitney sells the spring bushings for our trucks. It's the only place I've found that I can get them for my 72 K-10. Napa lists everything up to 67, then the book skips to 73. They totally bypass our trucks.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 05-07-2003, 12:04 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
So just totally bypass NAPA.
J/K, the NAPA we deal with at work has our trucks in the books...even lists the 305/351 engines! The trouble is only one of the guys there reall knows how to use the books.
Old 05-07-2003, 01:27 AM   #5
O'l Buck
O'l Buck's Avatar
That could very well be the problem here Andy, The guys don't like to look in the books very hard when I go in there, and I'm always after something that isn't in the puter. I'd quit buying parts at Napa, but I don't wanna drive 60 miles to get to any other store. They kinda got a monopoly here.........the same guy owns the 3 stores closest to me as well.....but he's a good friend of my dad's, so we get a decent discount.
Chad
