03-31-2012, 05:31 PM | #1 |
Truck and auto performance nut
DBW pedal - what did you use?
OK 67-72 guys....I've come across an issue here or there I've worked thru...but this one I'd sure take some ideas on based on what others have done that works.
The '07 DBW pedal assembly kicks to the right of the mount...our kick to the left.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
03-31-2012, 07:37 PM | #2 | |
Re: DBW pedal - what did you use?
But FWIW, Corvettes use the same pedal as a "71-2 trucks, you can even put the stainless piece on them. But it all depends on what you are using for PCM, TAC ect, as they have to match.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-31-2012, 07:40 PM | #3 |
OK, I just re-read your post, the 2007 uses the all plastic pedal, and they are kinda hard to weld on! On my '07, I took the original pedal and welded a bracket that I in turn bolted to the plastic pedal after cutting most of it off. I can get you a pic tomorrow if someone doesn't beat me to it.
03-31-2012, 08:35 PM | #4 |
Not sure what you are looking for in a pedal but Lokar has some, here's a link http://www.jegs.com/p/Lokar/Lokar-Dr...76013/10002/-1
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy C-30 1-ton 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2005 Dodge Ram 2500 5.9 Cummins 2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins 2020 Jeep Wrangler Unlimited Rubicon |
04-01-2012, 03:11 PM | #5 | |
as far as an epoxy job...got a product recommendation for the job?
04-01-2012, 08:23 PM | #6 |
Here ya go! Where it's bolted to the plastic part, I made a metal part that kind of "wraps" around it, and it actually would hold with out the bolts, but it was loose, so I bolted it. Ignore the oil pressure gauge hanging there, it's only temporary!
04-01-2012, 11:42 PM | #7 |
meowMEOWmeowMEOW
Belzona super metal is really really hardcore stuff, if you can repair a aircraft carrier with it, probably should work for this.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
04-01-2012, 01:01 PM | #8 |
the Lokar stuff is nice no doubt....but a bit pricey. They make you buy 2 pieces....the pedal assembly and the control module...meaning a tab of well over $400 before you're thru. At least....thats the way I read it.
Thanks for the Frankenstein idea! I had wished it was metal instead of plastic so I could weld my original to it...didn't think of "bolting" to it. Sometimes its the simplest things!
04-01-2012, 01:53 PM | #9 |
meowMEOWmeowMEOW
You may consider cutting the plastic and setting it in a "jig" in the position you want. You could then use an epoxy/resin with some light metal rod and "cast" your own.
It sounds like a huge hairy pain in the a$$ but I'd be afraid of bolts creating a stress point in the abs plastic.
04-02-2012, 12:59 PM | #10 |
that looks great...can't quite tell how the pedal bar is cut/formed tho and what the top cover accomplishes.
I've used j-b weld quite a bit and if there's an epoxy as strong it ought to work!
