Old 04-01-2012, 04:58 PM   #1
Tim Christian
Tim Christian's Avatar
I need a picture????
I need a picture of how the Temp Sensor wire runs on a 1970 CST with a 350 V-8 It has two brackets on it that bolt somewere??? Thanks Tim
Tim Christian is offline   Reply With Quote
Old 04-01-2012, 09:15 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: I need a picture????
On my 1969 CST/20 with 350 the wire runs along the top edge of the left valve cover then curves around the front of the head, under the exhaust manifold then up to the sensor between cylinders 1 and 3. There are a couple clips welded to the valve cover to retain it and also a connector attached to the top driver's side stud holding the water pump. I don't think I have a picture showing the clips or routing. Also, the wire was run through a 1/4" fabric loom.
FirstOwner69 is offline   Reply With Quote
Old 04-01-2012, 09:40 PM   #3
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
AH just re-read your post & caught the bit about the fabric loom. Thanks!
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 04-01-2012, 09:59 PM   #4
MusicMan70
MusicMan70's Avatar
Here's a pic of one bracket next to the water pump; silver-colored...the loom part is old and a bit frayed. I don't recall a second bracket just the clips mentioned by FirstOwner69. Clips just below Quadrajet linkage.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 04-01-2012, 10:18 PM   #5
FirstOwner69
I found some pictures.
The 1st 2 are as it's been for 42 years. The 1st not very good shot shows it curving around the front of the head and exhaust manifold and what remains of the fabric loom (lower left of alternator pilley). The 2nd shows it along the valve cover (looks like there's only one clip just to the right of where the 2 wires cross and the wire is not actually in it in the pic). The clip is barely visible in the resized picture...sorry. I don't recall what the brown or black wire is. The third is a shot of the retainer clip at the water pump on the truck as it exists today.
The early Corvettes used clips that were attached under the top valve cover bolts. Perhaps that's what yours has. If you don't have the clip welded to the valve cover, you could order some of those used on the Vettes.
Old 04-01-2012, 11:21 PM   #6
FirstOwner69
Here's a picture I copied from an old classified ad on this forum. It shows 2 clips on the valve cover.
Old 04-01-2012, 09:39 PM   #7
oldgold70c10
Who's got steelies?
Reading minds? I was thinking of posting this exact same question earlier today!
I haven't seen an illustration in any of the manuals that shows how the wire runs. In the factory routing, does it have any kind of hi-temp cover over it where it is near the exhaust.
Waiting for pic x2!
My Truck Page
My Youtube Channel
Old 04-02-2012, 07:20 PM   #8
Tim Christian
Thanks guys this helps a lot !!!!!!!!!
