04-03-2012, 06:50 PM | #1 |
Taking the plunge
So I took the plunge today, ordered the swap from a salvage yard for my 84. The guy says it is from an 07 Chevy truck 5.3 with the PCM, harness, pedal assembly, pedal computer, all accessories, fuel lines and 4l60 transmission. All with 58kmi on it for 2k picked up with a 90 day warranty.
The bad is the place is like 50miles from my house, so I really need to inventory everything when I pick it up. Anything I should look out for when I go pick it up? Does the price sound right? |
04-03-2012, 07:27 PM | #2 |
Still Just Havin Some Fun!
Re: Taking the plunge
get everything you can. Breather assembly, holder for the computer, radiator if its good, shroud or anything you can.
a green one with some stuff done to it.... |
04-03-2012, 09:30 PM | #3 |
O2 sensors tac module for pedal cooling fan electric or manual
Posted via Mobile Device |
04-03-2012, 10:05 PM | #4 |
He said the pedal computer (I assume tac module) would be included, I will have to make sure it is there. I'll make my list before I head over. They seem to sell quite a few according to him.
Just got my truck back on the street and hat the 305 in it and dealing with the bent frame. Time to blow it back apart and do it right. Never done a motor swap, but you only learn by trying; so I will be asking lots of questions. |
04-03-2012, 11:53 PM | #5 |
This is awesome site lots of info suggest you read the ls swap threads that's wear I got what I need
04-04-2012, 05:09 PM | #6 |
Thanks! I have been reading all I can in the build threads for the past few weeks. My only problem is if I want to keep it smog compliant I could run into issues. Found out the engine is a L59 out of a 2006 Chevy Tahoe Z71 5.3L. The Flex Fuel option worries me a bit.
04-04-2012, 06:35 PM | #7 |
JRods Garage
Right on bro! Im a somewhat close neighbor doing a similar swap... I actually think you were the one I talked to at the CPP cruise
Orange Julius-My dropmember'd, LS'd, SWB street machine... |
04-05-2012, 10:42 AM | #8 | |||
Yep, it was actually on the list the guy gave me of things, I forgot it until then. |
04-05-2012, 12:20 PM | #9 | |
JRods Garage
Hell yea man, you can come by whenever... i work during the day on weekdays, but im home by 5 and I have every other friday off.. Im in the process of figuring out how to get the truck away from my garage wall(air compressors not currently working) but once it is, its teardown time
04-05-2012, 03:54 PM | #10 |
The yoke from your 350 turbo will work in the 4l60e. The driveshaft length may be too long and need to be shortened depending on where you put the engine
Also, L59 is the desigination given to the flex fuel engine, its an option for the truck, not the engine its self..Posted via Mobile Device
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html Last edited by ls1nova71; 04-05-2012 at 04:04 PM. |
04-04-2012, 07:30 PM | #11 |
A guy with a truck
Flex fuel is no biggie- actually I think you get bigger injectors- bonus! DoD or vvt would worry me more
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-04-2012, 10:46 PM | #12 |
Home Built '87
Get the driveshaft too if there is any question whether your old one will fit (number of splines) on the new trans.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
04-04-2012, 10:59 PM | #13 |
Be sure to get the gas pedal and also the harness between it and the TAC.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
