98 Vortec 350. Fuel pump help!
Hi all, so I have a 98 Vortec 350 that a had rebuilt back to stock. Except it has a edelbrock carb intake. Because im going that way. So my plan was to put a mechanical fuel pump on it because it has provisions for one. My question is can I do this? I was told that I needed a special pump rod for this? Because its a roller cam I guess? O ya it's going in my 72 k10 swb. Is this true? Any suggestions? Thanks.
1972 k/10 4x4 swb 2011 camaro SS/RS M6 |
Re: 98 Vortec 350. Fuel pump help!
you can get one from jegs or summit that has a bronze tip $21 or a roller tip $100+ roller cams are steel not iron and i guess the lobes aren't heat treated. somebody here knows the story. i ran a bronze tip one with a roller years ago. does chevy make a stock one?
1961 chevy K10 my build is------------61K10 build |
Some roller cams don't have a lobe for mech. fuel pump.
Posted via Mobile Device |
Ive never seen a production 98 vortec block have the hole for the pump rod.
Like 1972CST said the Factory Production cam WILL NOT have the lobe |
The mount is still cast on the block but there is no hole for the pump push rod. If you are rebuilding a block the hole can be drilled but not on a used install because you risk metal shavings getting into the block. I think that factory cam does not have a lobe for the mech pump. The easiest way would be to go to the parts store and get a universal electronic fuel pump for a carb. like this from autozone.
http://www.autozone.com/autozone/par...1_173883_4967_
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
Junior Member
If you go with an electric fuel pump it is a good idea to also put a fuel pressure regulator in since the Edelbrock carbs like a constant pressure, I can not remember the exact number but I think it is 5 pounds.
Also the fuel pump should be mounted as close to the tank as possible.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Go with an electric pump. You can get a cheap one since you only need 5-6 pounds of pressure. It helps with vapor lock if running high compression or headers. Easier to replace too. I had four different kinds of pumps on my 68 camaro before I went electric.
Tags |
350, 5.7, fuel pump, vortec |
