Old 04-07-2012, 01:31 AM   #1
CrazyJesster
CrazyJesster's Avatar
harness questions
so did some of yall work your own harness to go into the squares?
or did you have it done by a shop like nelsons or wheatly.
i checked a price at nelsons in san antonio and it was 450$..
with all you gurus that have done the ls swap before
can it be done by me? with help from here of corse
what all is involved labeling and ?
Project 82 ReBoRn http://67-72chevytrucks.com/vboard/s...d.php?t=441842
CrazyJesster is offline   Reply With Quote
Old 04-07-2012, 10:27 AM   #2
ls1nova71
ls1nova71's Avatar
Re: harness questions
Go to LT1swap.com and study it, it will tell you just about anything you would need to know about making your harness stand alone. If you have specific questions, they can be answered here, but for an over all" how to" Brendan has done a great job of taking the leg work out of it with his site.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-07-2012, 12:04 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
My harness was about $500, but it was setup for everything I wanted, and came with its own nice fuse panel etc. Was totally worth it imo, just not having to screw with it. I liked having un-cut connectors etc underhood.
My truck needed a ground up rewire anyway, saved me a f ton of time.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-07-2012, 06:29 PM   #4
Daaaanz67
Thanks to lt1 swap used current performance fuse box also this site did my own
Daaaanz67 is offline   Reply With Quote
Old 08-29-2012, 02:28 AM   #5
CrazyJesster
which current performance fusebox did ya get ?
this maybe the route i take
Old 04-07-2012, 11:18 PM   #6
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I have a Nelson custom "stand alone" harness. I'm still in the installation phase so I cannot comment on the finished product so to speak....but its a quality harness. The leads are all well labeled, everythings shrink wrapped, with new correct connectors, and covered with that black nylon mesh protective covering. I've got one lead a little short but otherwise the fit has been great. Has several relays and a new add-on fuse panel. I worked a trade with him on something so I can't speak to costs, but he supplied my harness, e36(e38?) ecm and a 4L80e tcm, along w/intake, etc.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-07-2012, 11:33 PM   #7
clinebarger
Do your own! Its to easy to pay $400-$500 for a harness. Putting a LQ9 in a 77 Silverado right now....Using the original 05 Escalade engine harness & fuse box, DONT cut the harness up....Leave it alone & tag what you need at the fuse box.
clinebarger is offline   Reply With Quote
Old 04-07-2012, 11:47 PM   #8
CrazyJesster
ill need to go to a junk yard and get an under dash harness.
with the obdii port on it im guessing it just plugs into the main harness??
Old 04-07-2012, 11:57 PM   #9
clinebarger
Just get the OBDII port with about 6 inches of wire, You will have to wire a serial data wire going to the PCM, The grounds & power can be handled under the dash.
Old 04-08-2012, 12:14 AM   #10
gringoloco
A guy with a truck
gringoloco's Avatar
Diy ftw!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-08-2012, 04:44 PM   #11
dkauffman05
dkauffman05's Avatar
I did mine for about $100 pulled from junk yard and help from lt1 swap. I did the engine part while yhe motor was on a stand so i could rout everything how I wanted to,plus i moved coils to rear of heads snd routed some under the intake .when you look at mine you only see very few wires.
dkauffman05 is offline   Reply With Quote
Old 04-11-2012, 08:49 PM   #12
softballnrd27
Always a work in progress
softballnrd27's Avatar
I am almost done with mine. It isn't hard but it is very time consuming. Take your time and do it right. I have my alt, tips, iac, and maf routed under the intake. I will take a picture tomorrow and show you what it looks like so far. I also turned my injector plugs toward the intake to hide the wires some.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 04-12-2012, 06:47 PM   #13
dkauffman05
I did the exact same thing as above with routing wires under the intake and turning the injectors around.
Old 04-12-2012, 10:48 PM   #14
softballnrd27
It's amazing how much turning the injectors inboard hides the injector harnesses isn't it.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 04-13-2012, 11:36 AM   #15
OneOffStroker
I did it myself with Branden's site as a guide. Took about 2-3 days, but I did a lot of custom work as well. I also turned my injectors around, but I ran my MAF, TB, MAP, and knock sensors ontop of the manifold. I'm using the VORTEC cover, so it all disappears the same. I also re-routed everything so that the main harness bundle comes together at the rear of the driver's side valve cover, then disappears into the firewall. The vast majority of the wiring as well as the fuses, relays, ECM, and TAC are inside, under the dash. You can't really see any of it once it's hooked up. Trans wires run inside and to the trans/VSS through the hole in the floor for my B&M floor shifter.
I'll post pics in my build thread once I get it started.
OneOffStroker is offline   Reply With Quote
Old 04-18-2012, 09:34 PM   #16
Dustytrix
I would like to see how yall routed the wires under the intake before I pull my engine and start the swap. I hope I have my harness done correctly, I used the lt1 swap site so it should be close I hope.
Dustytrix is offline   Reply With Quote
Old 04-19-2012, 10:04 AM   #17
OneOffStroker
Honestly, you don't gain much by going under the intake as oppsed to going on top like stock, unless you are not going to use the VORTEC cover. With the cover in place, you won't see the wires routed on top. I did mine this way, and it is still super clean.
But...if you must go under the intake, there is a ton of room. there are 2 foam inserts stuffed under there from the factory, so it doesn't look like much, but with them out, there is 2-3 inchees of room to work with.
I'll snap a few pics when I get home and post them tonight.
Old 04-19-2012, 08:24 PM   #18
OneOffStroker
Here's the intake with the foam removed. Plenty of room for wires if you want to go this route.
Second pic is with cover on and wires routed on top of intake.
Old 04-24-2012, 09:02 PM   #19
Dustytrix
Thanks for the pictures, I see what you're saying. By the way that is one clean engine. I will have to try and locate me a cover like that.
Old 08-26-2012, 03:08 AM   #20
CrazyJesster
well for my swap my engine is out of a 2000 model truck. so i guess i could go an get a under hood fuse panel from a junk yard?
im not sure if i can handle doing this alone but money is a big issue. and i cant really drop 4 to 500$ on getting some fancy harness.
if i add cam headers etc im already short on funds then need my tune heh.
going to be a long time to get this going heh
Old 08-26-2012, 08:00 PM   #21
clinebarger
Get a 99-02 truck fuse box, Get the Grey, & Red bolt-on connectors, Cut the wires at about 6 inches, most will be removed later.
There is a Black sealed stand alone connector under the fuse box (arrow) That you need also.
Get this & it will be EASY, I will post diagram & tell you what to do when you get the parts.
Old 08-28-2012, 12:42 AM   #22
CrazyJesster
6 inches from where ?
will the grey and red bolt on connectors be with the harness or on the cab ?
sorry im kind of confused
Old 08-28-2012, 08:06 PM   #23
clinebarger
The Grey & Red connectors bolt to the bottem of the underhood fuse block.
Here some drawings to help, Cut where the arrows are. Just leave the Grey & Red connecters bolted up to the fuse block, These connectors are part of the body harness.
C1 Grey
Old 08-28-2012, 08:08 PM   #24
clinebarger
C3 Red
Old 08-28-2012, 11:46 PM   #25
CrazyJesster
so the stuff that is beeing cut what is it connected to originaly? an hold harness?
