Rear Crossmember same between 64-66 SWB and LWB?
First off, I googled this picture to use for reference, so if it's someone who wants me to remove it, just let me know.
Anyway, thinking about picking up a SWB frame to convert my 65 C10 LWB into a shorty. The guy sold the 'rear crossmember' where the trailing arms bolt. ![]() Does this piece interchange between the LWB and SWB frame? Can I just use the piece off my '65 and still use this frame?
____________________________ |
Re: Rear Crossmember same between 64-66 SWB and LWB?
I'm going to "assume" they are the same up until '72?
http://www.performanceonline.com/196...pension-19834/
Never Ending Projects
I believe they are the same from '63 to '72. You can use an original or an aftermarket crossmember.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Thanks, that what I was hoping.
![]() Join Date: Apr 2012
Only difference I have seen, is the LB has a two piece drive shaft with a carrier bearing, where the SB will have a one piece shaft. But the cross member itself is the same.
I have not failed. I’ve just found 10,000 ways that won’t work. |
Thanks for the input. I figured they were all the same, but you know what they say when you 'assume' something.
