04-12-2012, 11:40 AM | #1 |
Gas tank hose and hood hinge ?
For my 78 K10 with dual tanks, does anyone know where to find the fuel filler hoses to replace the originals. I don't know if I'm searching the wrong name but I've had no luck finding them.
And hood hinges, I just bent my second hood. I'm going to order a new one and was just wondering if anyone has come up with a solution to the old spring design, or can they be rebuilt in a way that makes them a bit softer in operation. Also if any local las vegans with K series trucks are looking for parts, pick a part on lamb has 4-5 trucks right now with some really nice running gear,parts. Posted via Mobile Device |
04-12-2012, 09:28 PM | #2 |
Re: Gas tank hose and hood hinge ?
LMC Truck has the filler tube for 19.95
Part number is 32-3302 for a 75-78 They also have a hinge brace extension for 19.95 that eliminates the hood bend issue. Part number 38-0783 The big thing with those hinges is lube, use a good quality long lasting lube and hit every moving part, should work like a charm. www.lmctruck.com Happy hunting.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
04-12-2012, 11:46 PM | #3 |
Moderator
I use Wurth HHS2000 it's a real good lubricant that flows out like water and lubes better than grease after the solvent flashes off. Go easy till you get a feel for how much to use because a little goes a VERY long way.
http://www.amazon.com/Wurth-HHS-2000-Penetrating-T... |
