Need help on understanding what i need for headlights
I am looking to add the heavy duty headlight harness that LMC offers. I also wanted to upgrade to sylvania silverstar halogen bulbs. Could use some assistance on what exactly i need. I have an 87 R10 and i am looking to replace all four lamp housings as they are fogged over and condensating on the inside. Any and all help is appreciated. Thanks!
![]() Join Date: Mar 2012
Re: Need help on understanding what i need for headlights
You will need the 4 lamp housings to fit your truck, 4 bulbs (2 low and 2 high) and the wire harness. Depending on the wire harness, it should be pretty straight forward. A battery connection, a couple relays and some ground wires.
As far as I know they don't make composite headlights for the 4 light 89-91's...
I hope someone can prove me wrong! Posted via Mobile Device
#4 | |
To the OP. I believe with the LMC harness and the Silverstar bulbs....the only other thing you would need is the light housings themselves. What kind do you want? Clear lense where the reflector directs the light, or fluted lens where the lense directs the light?
1995 Suburban K2500 454.....off road & towing 1999 Astro, work van 2006 Silverado 2wd 5.3 w/4.5" lift and 33s |
#5 | |
Cool I'll do some searching Thanks!! Posted via Mobile Device
My post was supposed to say: I can search for the Camaro site if you'd like.
Obviously you can look too, but I'd probably have an easier time finding it. Edit: Here's the site. They're the 4701 and 4703.
1995 Suburban K2500 454.....off road & towing 1999 Astro, work van 2006 Silverado 2wd 5.3 w/4.5" lift and 33s Last edited by TheApocalyptican; 04-13-2012 at 10:08 PM. |
#7 | |
I wish someone made a one piece quad lights... Posted via Mobile Device
