Old 04-16-2012, 05:41 PM   #1
MrLimo
sending unit issue
Hey all, thanks for reading. I'm new to this forum, and new to the world of the 60-66 GMC/Chevy (Notice the GMC first?) world! Purchased one recently and it's gonna be a slow build, but I'll start a thread with some photos so you all can see.
I have an initial question for everyone tho, as it has me a bit stumped regarding the fuel system.
66 GMC truck (I believe it's a C1000) has the original gas tank, sending unit and gauge. When I bought The beast, gas gauge did not work. Figured I'd buy a new gauge and sending unit to replace what was factory. After investigating, realized the fuel line comes out of the mount for the sending unit, so I decided to see if I could fix what was there. Pulled the sending unit from the tank & saw that the flat "wire" that connects to the outside of the sending unit was broken. Soldered a new one on the end of the flat 'wire' that's factory, and attached it to a new screw sticking out of the top of the unit and it works! Great, can see how much gas I have so I don't run out (had already done it twice at that point!), but come to find out it actually works intermittently. No rhyme or reason as to why, just sometimes it registers the amount of gas, and other times it's pegged at Full.
Any suggestions?
Thanks!
Chris
MrLimo is offline   Reply With Quote
Old 04-17-2012, 11:35 AM   #2
MrLimo
Re: sending unit issue
Anybody? Any ideas?
Old 04-17-2012, 11:58 AM   #3
1963c-10
1963c-10's Avatar
Grounding issue. Check the ground from the tank to the cab wall and make sure the guage is grounded good.
1964 Short bed trailer
Old 04-17-2012, 12:45 PM   #4
MrLimo
Thanks C-10. I did check the ground from the tank to the cab & that seems to be pretty good, but I didn't think to check the gauge. I'll do it today when I get home.
Old 04-17-2012, 12:46 PM   #5
1963c-10
1963c-10's Avatar
The guages are grounded throug the cluster housings. I would suggest adding a ground from the guage to the cab or firewall
Old 04-17-2012, 12:53 PM   #6
1963c-10
1963c-10's Avatar
Also check to make sure the sending unit wire is tight into the fuse block. It plugs in at the bottom left of the fuse block
Old 04-17-2012, 04:10 PM   #7
MrLimo
Thanks for that one too. I'll check it today too.
Limo
Old 04-17-2012, 05:47 PM   #8
kieth
kieth's Avatar
To check the gauge itself disconnect it from the fuel sender, add 12 volt power and then ground the lead that goes to the tank. If the gauge goes to full when grounded then it is ok. If it does not move (like mine then the gauge is bad...... Kieth
kieth is offline   Reply With Quote
Old 04-17-2012, 06:46 PM   #9
ol_skool_chevy
ol_skool_chevy's Avatar
I did the same thing once to mine.....and come to find out..your not suppose to weld or Solder on sending units.....it burns the element out and it HAS to be replaced....I replaced mine and works great now..
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 04-19-2012, 10:51 AM   #10
MrLimo
So, I took the sending unit apart, and the contact inside seemed to be a bit dirty and corroded. I cleaned it up, put it back and it seems to be OK now. At least I know for certain that it's not the gauge, or a ground at the gauge. I guess if it fails again, I'll try to find an OEM sending unit to replace what's there.
Old 04-17-2012, 08:37 PM   #11
MisterC
MisterC's Avatar
I had almost the same scenario when I bought mine. Ultimately, I found the sending unit to be intermittent. I replaced it and have never had a problem since.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 04-19-2012, 10:54 AM   #12
MrLimo
Were you able to find an OEM sending unit?
Old 04-19-2012, 10:57 AM   #13
MrLimo
Thanks to all who looked, I appreciate it. I did take the sending unit apart, cleaned it up inside, made sure that it appeared to be making good contact and it's working! Works 100% of the time when it's not in the tank, then I'd put it back in the tank and it wouldn't want to work. Removed it a couple of times fidgeting with this & that, and now it appears to be working. I still think there may be a grounding issue, but I'm not 100% sure. For now it works, who knows what tomorrow will bring!
Old 04-19-2012, 01:24 PM   #14
MisterC
MisterC's Avatar
The sending unit I found is not OEM. I found the Spectra Premium FG119A Sending Unit on the Autozone site and then ordered it from Amazon at a significant savings.
Old 11-17-2012, 09:14 AM   #15
RoyL
RoyL's Avatar
Sorry to highjack but is related to this sending unit above. Searched around and found no definitive answer on the issue of whether these sending units are 0-30 ohms or 0-90 ohms? I am working on a 1965 GMC and have read that the sending units changed in 1965 to 0-90.
the one in the tank is a 0-90 ohms, and needs replacing. Trying to make sure I get the right one.... The only sending unit I found that said what ohm range it was, was from Bob's Chevy Truck, it said 0-30.
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 11-17-2012, 11:54 AM   #16
luvbowties
luvbowties's Avatar
Thumbs up Re: sending unit issue
AFAIK, all the trucks thru 1966 use the 0-30 ohm units. Don't recall the site, but one of the on-line suppliers specifies this. If I find it shortly, I will reply back w/the link to help you "feel secure" this info is correct. HTH,
sam
luvbowties is offline   Reply With Quote
Old 11-17-2012, 03:23 PM   #17
luvbowties
luvbowties's Avatar
Smile Re: sending unit issue
FOR STOCK FACTORY GAUGES: I guess we all are familiar with the name of Eckler's for parts--hence we maybe trust them. Look at this link & see for sure that our trucks from 60-66 all used 0-30 ohm sending units. Did not go to 0-90 ohms 'til 1967 on the trucks, even tho' GM cars changed earlier.
>> http://www.ecklerstrucks.com/chevy-t...1960-1966.html <<
Here's another supplier, Car Parts Discount, who shows specifically a 1965 GMC as having 0-27 ohm senders--I guess GMC was a tad more accurate & got it down to the "fine print", being more exact: their gauges prolly did not read beyond "F" when filled like our cheaper Chevies. Naturally, in the grand scheme, 0-27 is practically the same to such a circuit as 0-30 would be.
.....for GMC 1000-series (read their 0-27 ohm spec in description)
>> http://www.carpartsdiscount.com/auto...html?3593=2627 <<
...for GMC 1500-series: (read their 0-27 ohm spec in description)
Hope some of this helps,
sam
Old 11-18-2012, 09:48 AM   #18
RoyL
RoyL's Avatar
sam
Same,
Awesome, thx! That settles it, there's conflicting info out there for sure . . .
Now for my sending unit, it has 90 ohms stamped on it, but it reads up to only about 38-40 ohms . . . put it back in and reads about right, I'll fill up today and see if it goes to full . . . Maybe it's not bad.
Thanks again! This forum is great!
Roy
Update: filled up and gauge reads full! It works, even though its stamped "90 ohm" on the sender itself...
1965 Suburban
Old 04-19-2012, 02:42 PM   #19
MrLimo
Mister C, I went and found it at Amazon as well, if what I did doesnt take, I'ma buy it. Always like to try to fix it first, but this one may get the better of me!!
Old 04-20-2012, 01:14 AM   #20
70cst
70cst's Avatar
Here is a bump ...
Hey MrLimo ...
to the forum and from Ohio
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
