Old 04-17-2012, 11:57 PM   #1
80c10
15X10 wheel fit 1980 c10 without tubbing
I have recently bought a 1980 c10 swb stepside, and im looking forward to putting some weld racing pro star's on it. I want to do 15 x 8 in the front and 15x10 in the back is it possibly to fit the 15x10 in the back without doing any tubing what so ever. If yes can anyone give me all the information i need before buying the wheels (bolt circle, backspacing and what not). Sorry if i sound like an idiot first time buying aftermarket wheels for a truck! I wanna make the truck look sick ! i added a picture of how it sits now
80c10 is offline   Reply With Quote
Old 04-18-2012, 12:02 AM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: 15X10 wheel fit 1980 c10 without tubbing
Yup they will fit but not sure on the backspacing. I know the bolt pattern is 5 on 5. Do you plan on lowering the truck? I like the stock height with those wheels myself...
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 04-18-2012, 12:07 AM   #3
80c10
yes i do plan on lowering it, i have another thread debating on how low to go without bottoming out everywhere! someone told me that 5 x 4 3/4 fit does that sound right to you?
Old 04-18-2012, 05:47 AM   #4
Pop's C-10
Pop's C-10's Avatar
no..trucks are 5x5 bolt pattern.. 5 x 4 3/4 is car pattern..like camaro or a-body..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 04-18-2012, 01:08 AM   #5
69GMC910
MOTORHEAD!
69GMC910's Avatar
15x10 with a 4.5 backspace is the perfect size. That is what I run with a 30x12 M/T Sportsman S/R and it sits dead center with about 5/8" clearance on each side of the tire.
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 04-18-2012, 01:14 AM   #6
80c10
perfect! and THank! hey i was gunna run those tires as well do they hook up nice on the street and track?
Old 04-18-2012, 01:21 AM   #7
80c10
what would the recommended spacing for the 15X8 in the front so it looks smooth
Old 04-18-2012, 01:41 AM   #8
74 stepside
74 stepside's Avatar
15x8 in front with 4" bs. 15x10 in rear with 5" bs.
74 stepside is offline   Reply With Quote
Old 04-18-2012, 09:06 AM   #9
J Knight
J Knight's Avatar
X2 on this for 15x 8s & 10s to tuck without rubbing the fender lip.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 04-18-2012, 01:41 AM   #10
Low84
Low84's Avatar
15x10 will fit out back
Here's a pic of mine:
Your bolt circle pattern should be 5x5 if it is stock though!
Low84 is offline   Reply With Quote
Old 04-18-2012, 06:06 AM   #11
baclay9
If you are gonna be tucking tire you need 5" backspacing in the rear.
baclay9 is offline   Reply With Quote
Old 04-18-2012, 06:32 AM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
20x9.5 (with 5" BS) with air ride.
These 295/40-20 tires will tuck under the stepside fenders.
Your desired ride height will dictate what backspace you need.
Keith
Convert to disc brakes.
Old 04-18-2012, 12:15 PM   #13
69GMC910
MOTORHEAD!
69GMC910's Avatar
I can't tell you about traction on the m/t sr's... I have heard they are good for street driving, but with my combo I highly doubt I'll have traction at 60mph let alone from a stand still... Far superior to a radial t/a tho...
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 04-18-2012, 12:16 PM   #14
69GMC910
MOTORHEAD!
69GMC910's Avatar
I'm still in the assembling process....
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 04-20-2012, 11:16 AM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
I suggest you go with spindles in front and a cut coil if you want more. For the rear, shackles and hanger if your going to stick with 4". You can remove and raise the stock hanger out back, but you won't get a full 2" drop.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-20-2012, 12:21 PM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
BTW- Check our Suspension Marketplace or Vendors Marketplace for great deals on suspension packages,
Articles-
"Refining Sierra"
Old 04-20-2012, 05:52 PM   #17
Weasel Diesel
Sure 10" will work.... here's my 15X12... 5" backspace
Weasel Diesel is offline   Reply With Quote
Old 04-20-2012, 07:09 PM   #18
Pro Performance
Pro Performance's Avatar
The kits are a great way to go, and the 2.5/4 is a nice mild drop.
Pro Performance is offline   Reply With Quote
Old 11-14-2012, 11:43 AM   #19
Gigem
Gigem's Avatar
Hey all, I just bought this truck from 80c10... My plans are a bit different than his...
I am going to make a driver out of this truck, first for me and potentially later for my son who is about to start driving...
Looking to put a GM Performance small block crate motor in it, either the 290 hp or 330 hp. Will probably swap out the SM465 for an automatic transmission. And since we are in Houston, it will definitely get air conditioning, likely Vintage Air.
As far as wheels and tires go... I like the stock ride height, and have no plans to lower it at all. I don't really like the "big and little" look on these trucks, so I'll be looking for a tire/wheel combo that can fit on all four corners.
I am thinking 15x8 American Racing Outlaw II wheels, with a 285/75/15 tire... Think that will fit OK?
Gigem is offline   Reply With Quote
