04-18-2012, 08:46 PM | #1 |
WTB Crank/PS pulleys and valve covers
I need a 2 groove crank pulley, 1 groove PS pulley and some original style valve covers for my 72 with 350 engine. No bends or dents please. Thanks, Bob
04-19-2012, 01:28 AM | #2 |
Happy Camper
Re: WTB Crank/PS pulleys and valve covers
I am going subscribe to this, if you dont get help on it before Monday I think I can find this stuff for you. (I can't check until Monday). Good luck!
RIP El Jay! Love you brother! |
04-19-2012, 02:15 AM | #3 |
"Junkyard Dog"
15.00 on the crank pulley, 25.00 on the valve covers, hot tanked & dipped. Like new. Which P/S crank pulley do you have? Is it cast iron or stamped steel? The crank pulley determines which pump pulley is used. Plus shipping.
Thanks, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
04-19-2012, 02:20 AM | #4 |
Any chance you know casting/stamping numbers of which crank pulleys combine with which water pump and power steering pulleys?
04-19-2012, 06:37 AM | #5 | |
Thanks, Bob |
04-19-2012, 10:59 AM | #6 |
This is for an early 80's block as far as I can tell. It currently has a steel crank pulley for a long waterpump. I'm changing to a short pump along with brackets etc. needed for P/S pump and Alternator. You have me wondering if a cast crank pulley, which would weigh more, works with the balancing of the rotating assembly? In other words if I put on a cast crank in place of the steel would it throw it out of balance?
04-19-2012, 11:13 AM | #7 |
your engine is internaly balanced, the pulleys wont effect it. sounds like you need a complete set of pulleys, 2 that bolt to the balancer, 1 for the waterpump, and 1 on the ps pump.
04-19-2012, 04:34 PM | #8 |
Just like to part out trucks!!
I will have all the motor pullies and valve covers on a truck I just hauled in. I have the ps pulley but its on a pump and brackets. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
04-20-2012, 02:10 AM | #9 |
"Junkyard Dog"
Sorry, I don't have a pump pulley separate from a pump assy. 27.50 for both crank pulley's. Thanks, Tom
04-20-2012, 07:25 AM | #10 |
So, mostly likely my truck originally came with a single groove steel crankshaft pulley with an add on pulley behind it for the P/S pump?
Would that then affect the water pump pulley alignment? Sounding like I need to find a set of 4 - W/P, C/S and addon for P/S, and the P/S pulley to insure they all line up correctly. Is that the better approach? |
04-21-2012, 01:18 AM | #11 | |
"Junkyard Dog"
04-21-2012, 08:20 AM | #12 | |
Thank you Tom, Bob |
