finding gear ratio
i have looked every where and i just picked up this truck and the rear pumpking is knocking bad so im trying to figure out the gearing of this to just get a new axle...the sticker in the glove box is gone so i cant look on there any one know how to tell the gearing using the vin...thanks in advance
Re: finding gear ratio
You could take the cover and count the teeth. Also the ring gear should be stamped.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
Nope. There's no coding in the VIN that indicates gear ratio.
As bilfman says, you can pull the cover and count teeth (sounds like you need to be in there anyway) or do the old "roll the tire and count driveshaft revolutions" trick. If you can give me more details on your truck (year, model, engine, trans) I can tell you what ratios were offered - but there's no way to know what the original owner/dealer chose and no guarantee that it's still in there. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 04-19-2012 at 07:35 AM. |
Slight modification to my above post.
Depending on the model year ('77 and newer) you CAN send your VIN (and $50) to the GM Heritage Center and they can pull the original invoice for your truck. It will show all of the options, pricing, destination charges, etc. It will look like this: ![]() Link: http://www.gmmediaarchive.com/ Just depends on how badly you want to know ![]() Welcome to the site, btw. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 04-19-2012 at 07:34 AM. |
Lift the rear and count how many times the driveshaft rotates in the time the tire rotates once......... that will give you a very good answer to what gear ratio you have.
RIZ |
#6 | |
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#7 | |
The other opportunity would be if it was built in Oshawa, as GM of Canada keeps their own records and makes them available. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
i know what gear ratios were offered ill just take it apart and count the teath this sunday...thanks a lot guys ...ill be posting on here more often i just bought a 84 chevy half ton for 550 and already got a 4 inch lift for 125 and im gettting 35 inch super swampers on sat for 140 and ima do a 4 inch shackle lift it has a 305 which im going to upgrade to a 350 in feb(income taxs again) its gonna be an awesome mudder
You don't even have to count teeth,pull cover and there are some numbers stamped on ring gear.They will be something like a 41 and 10 or similar.the large number is ring gear teeth,small is pinion teeth.divide ring by pinion and that will give you ratio.
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" ![]() |
