Old 04-19-2012, 11:10 PM   #1
late68
late68's Avatar
Ever had to shim a bed???
MY body line from the bed to the cab is just horrible! Not sure what the fix is for this, or if there are some kind of mounts that go under the bed.... Any help would be greatly appreciated.
1968 C10 SWB Dropped 5 in tha back 3 in tha front
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902
late68 is offline   Reply With Quote
Old 04-19-2012, 11:18 PM   #2
old Chevy guy
old Chevy guy's Avatar
Re: Ever had to shim a bed???
Thats a lot. Just wondering,looks like your beds gonna have a wood floor? In the second picture it looks like theres no wood. The wood will raise the bed up the thickness of the boards wont it?
old Chevy guy is offline   Reply With Quote
Old 04-19-2012, 11:25 PM   #3
late68
late68's Avatar
No the woods not installed yet, but the wood go's on top of the bed rails so I dont think that this will raise the bed. I was thinking that some kind of rubber mount might go under the bed. But after some research I cannot find anything.
Old 04-19-2012, 11:26 PM   #4
Sillyoldman
#16876
Sillyoldman's Avatar
Yep wood will raise it 3/4". Thed bed mounts are metal on metal but they do sell rubber cushions for in between. They usually cause the opposite of your situation. Did you replace cab mounts? If so mybe check and make sure that's not causing any issues.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 04-19-2012, 11:28 PM   #5
late68
late68's Avatar
Yes all of the cab mounts are brand new. So how does adding the wood raise the bed???
Old 04-19-2012, 11:32 PM   #6
Sillyoldman
#16876
This is my '63 I can't find one of the '71 but they go together the same. Your front roll pan will go under the wood and the sides go over the top of the wood.
Old 04-19-2012, 11:35 PM   #7
late68
late68's Avatar
Oh okay I see. The wood lifts it front the sides.
Old 04-19-2012, 11:41 PM   #8
Sillyoldman
#16876
Yeah if you want to get an idea of how the body will line up just put some 1x4 in between the cross sills and the bed. The more I look at your pictures I'm guessing you will like the results.
Old 04-20-2012, 07:55 AM   #9
cdowns
cdowns's Avatar
could also b a problem if the cab mounts were not torqued down correctly and compressed to specs
Old 04-20-2012, 02:34 PM   #10
kev0519
4x4 cab mounts on a 2 wheel ???? Just an idea
kev0519 is offline   Reply With Quote
Old 04-20-2012, 09:48 PM   #11
pat 70/71
pat 70/71's Avatar
Based on your pics the wood will bring the bed up to the proper height When you put the bed together with the new wood. I did this on my stepper, square up the bed set it on the truck site through the tail gate to the front of the bed make sure they are parallel. And level with the body line on the back of the cab.
Shim the bed with simple washers until you are happy with it. Good luck and stay with it I know you will get it perfect! Cheers, Pat
pat 70/71 is offline   Reply With Quote
