The Peacemaker
CC10 Headers
They were ran for a few hours on my blazer(never driven around installed) and then removed because I sold the motor. I am not buying another small block and therefore these are just wall hangers unless someone else wants them. They were $480 including shipping from sanderson, and they fit pretty good. They have no dings and come with all original hardware.
Would like $380 shipped, and they have black thermal coating. A little info below; The CC10 is a swept back, shorty header with the collectors exiting along the angle of the firewall that fits 1964 and Up Chevelle and El Camino applications using the small block Chevy engine. This header is for straight plug cylinder heads only, and you should use "short" or "header" spark plugs for adequate clearance. If you do have angle plug heads, please order #CC10AP. Comes with all hardware necessary for installation. SPECIFICATIONS: Engine : Small Block Chevy 265-400 Primary Tube Diameter : 1½" Collector Diameter : 2½" Weight : 16 LBS / 7.26 KGS FEATURES: 16-Gauge Primary and Collector Tube Thickness 3/8" Thick Flange Patented Flange Design Requires NO Gaskets Tightest Fitting Header Available Anywhere! Made in the USA INCLUDES: Header Bolt Set OPTIONS: Our Aluminized Ceramic Coating is available and RECOMMENDED on all Sanderson Headers. We apply a multi-layer inside and outside silver ceramic coating in-house to meet our high standards of quality, and polish the coated header to a high luster. This coating provides aerospace and military technology to your vehicle to control the heat in your engine bay, improve cylinder scavenging of exhaust gases, and increase the longevity of your header investment. (read more here) You can select Thermal Ceramic Coating below, and the header price and part number will be automatically updated. Copper Collector Gaskets are recommended for all Sanderson headers (SEE RELATED PRODUCTS BELOW) Sanderson Headers do not include collector bolts due to our customers' wide range of preference. We do offer a collector bolt set that features Grade 8 Bolts with Locking Nuts (SEE RELATED PRODUCTS BELOW) NOTES: This header offers 1½" primary tubes, which is good for about 350HP on a casually used engine application. The CC10 is for straight plug applications only, and we recommend using "short" or "header" spark plugs. For angle plug cylinder head applications, please order part #CC10AP The Patented Leak-Free Design that Sanderson Headers offer you is the only leak-free flange design on the market ... Do Not Attempt To Use Flange Gaskets! The raised flange on the Sanderson Headers will buckle the gasket during tightening and actually cause a leak! Sanderson Headers are NOT emissions legal on pollution-controlled motor vehicles. It is the purchaser's responsibility to verify local regulations for compliance. Wrapping your Sanderson Headers with ANY thermal tape voids your header warranty. The best thermal protection for your headers is our Aluminized Ceramic Coating that is available for every Sanderson Header. WARRANTY: Limited 5-Year Warranty (read more here) DIMENSIONS: Tube Size ............ 1½" Collector Size ....... 2½" LEFT RIGHT DIM A ................. 3¾" 3¾" DIM B ................. 8½" 8½" DIM C ................ 24" 23" Weight (Lbs / Kg) . 16 / 7.26 Details SKU CC10-BEC Weight 16.00 lbs Our price: $425.00
1978 Chevy 2wd Stepside aka "Audrey" Cordova brown with mandarin guts 79k original miles & being restored 1979 Chevy 2wd Short Wide aka "Emma-Jayne" Cordova brown with mandarin guts 2019 Chevy Tahoe LT Previous rides: -2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB. |
![]() Join Date: Sep 2002
Re: CC10 Headers
do these have o2 sensor mount?
1963 C10 swb fleetside 1966 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
The Peacemaker
Re: CC10 Headers
The Peacemaker
Re: CC10 Headers
TTT
$350 shipped to buyers door.
Re: CC10 Headers
Still got them??
