Old 04-22-2012, 01:22 AM   #1
desertnick69
desertnick69's Avatar
Upper control arm Bolts!
I have gotten into the front end of my 69 chevy C-20 on a 71 frame. Need to replace it all. The drivers side every thing went smooth (as could be expected) The passanger side i had to cut off the upper control arm bolts.
These bolt are serrated and there is NO backing plate, the holes in the frame seems to be a bit out of round and a bit oversized. Whats the fix? weould send pics but don,t have working camera. Sorry guys)
desertnick69 is offline   Reply With Quote
Old 04-22-2012, 07:35 PM   #2
JimKshortstep4x4
Re: Upper control arm Bolts!
If the upper control arm bolts don't fit tightly in the cross member then it could be a problem! The bolts are held in the cross member with a press fit with the splines engaged to prevent the bolts from turning. Replacement bolts are available but it sounds like the cross member holes are too loose too hold them. My suggestion would be to replace the cross member unless there are replacement bolts with larger splines available.
Is the area around the bolts solid or is it rusty?
Here is a photo of the upper a-arm bolts installed in the crossmember for reference just to make sure that we are talking about the same thing.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-22-2012, 07:59 PM   #3
desertnick69
Where can i get replacement bolts
Old 04-22-2012, 08:49 PM   #4
desertnick69
Here are some pics of what I am talking about. te first pic is drivers side the 2nd pic is the passanger side. As u can see they are a bit bigger hole.
Old 04-22-2012, 09:00 PM   #5
fatgump
fatgump's Avatar
Contact forum member t korinek. He is very knowledgeable, has plenty of parts for these trucks and in Arizona. I have bought alot of parts from him and he is good guy.
fatgump is offline   Reply With Quote
Old 04-23-2012, 05:27 AM   #6
gysgtc
lmctruck.com has them. Pg 134 item 8. Other vendors probably sell them also.
gysgtc is offline   Reply With Quote
