Old 04-23-2012, 11:36 AM   #1
CHRIS67GMC
CHRIS67GMC's Avatar
Smitty's 67 Build
We are building a new Truck for Auto Cross and Road Racing probably a little Drag racing also. This will be a 1967 Chevy short bed.
Specs
Engine 434 inch small block Billet Crank, Crower Rods, Ross Pistons, Dart Heads, Comp Roller cam and shaft rockers. 700 hp
Trans T-56 with Dual disc clutch from American Power Train
Rear End Moser Fab 9 with 35 spline axles and a Al center section with a Wavetrac center.
Front suspension Rde Tech Arms, bags Triple adjustible shocks, sway bar amd a No Limit Steering Rack.
Rear suspensiom No Limit Fat Bar with Ride Tech Triple adjustible Shockwaves and a No Limit Sway Bar.
Brakes Wilwood 6 piston 14 inch rotors on front and 4 picton 14 inch rotors and the rear.
Frame boxed with tublar cross member and a full cage all chrome moly.
Starting point
Boxing Channels
Starting to Reinforce the frame
CHRIS67GMC is offline   Reply With Quote
Old 04-23-2012, 11:41 AM   #2
CHRIS67GMC
CHRIS67GMC's Avatar
Re: Smitty's 67 Build
Rear End parts from Moser
Dan from Clear Image Automotive Built me some custom Headers. Great place to deal with.
1 3/4 inch tubes with merge collectors and v-band clams.
Old 04-23-2012, 11:44 AM   #3
CHRIS67GMC
CHRIS67GMC's Avatar
I moved the engine as far back as I could without using the intake for a cup holder.
More Frame pics
Old 04-23-2012, 12:48 PM   #4
67cheby
67cheby
67cheby's Avatar
LOOKS like a BEAST !!
67cheby is offline   Reply With Quote
Old 04-23-2012, 01:05 PM   #5
Tinkermc
this is a wild thang I must keep watching
Tinkermc is offline   Reply With Quote
Old 04-23-2012, 01:08 PM   #6
VA72C10
VA72C10
VA72C10's Avatar
Nice! Like the plans for this one!!!
Old 04-23-2012, 03:29 PM   #7
robnolimit
robnolimit's Avatar
Lookin good Chris, I like the rear frame kick - nice
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 04-23-2012, 06:43 PM   #8
trkfrk
trkfrk's Avatar
This is going to be a build to watch.... Nice!
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 04-23-2012, 08:00 PM   #9
SOON2BLAZE
SOON2BLAZE's Avatar
chris, I remember that 67 gmc stepper in your avitar. Is it still around? Nicest one with a newer step bed I've seen.
SOON2BLAZE is offline   Reply With Quote
Old 04-23-2012, 10:24 PM   #10
YBNORML
YBNORML's Avatar
Sweet project! In for the ride
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 04-24-2012, 07:42 AM   #11
CHRIS67GMC
CHRIS67GMC's Avatar
Yes I still have the 67 GMC It was my first car purchase when I was 15 it will get a new make over as soon as this one is done.
Norwalk Drag 11.16 124
Sport Truck from back in the Day
Name:  Copy of DSCN1305.jpg
PHR tv
Name:  Copy of gmc-and-model.jpg
Name:  Copy of gmc-driving.jpg
Old 04-24-2012, 08:17 AM   #12
CHRIS67GMC
CHRIS67GMC's Avatar
Rob from No Limit built the fuel tank. It has baffles in it and extra ports for the return line and a #10 outlet welded right in. Super nice top quility stuff.
http://www.nolimitparts.com/
I found some cool hardware from Devil Accessories
He also has some cool door pulls/handles. These should make is easy to get out and to close the door when strapped in.
http://www.devilaccessories.com/
Old 04-25-2012, 11:48 AM   #13
djw32
Damn! This is going to be sweet!
djw32 is offline   Reply With Quote
Old 04-25-2012, 12:52 PM   #14
ccracin
CCTek
ccracin's Avatar
Very nice Chris! It's nice to see the right coast represented! Keep up the good work! I need to step up our progress!
Chad
68 swb Project
http://67-72chevytrucks.com/vboard/s...d.php?t=262840
72 swb Project SOLD
http://67-72chevytrucks.com/vboard/s...=1#post3993641
THANKS TO: Hermance Design (www.hermancedesign.com), Paradise Road Rod & Custom, Harry Opfer Welding, Tri-State Machine, Wegner Automotive Research, Nsane Hotrodz (www.nsanehotrodz.com), Clayton Machine Works, CCTek (http://www.candctek.com)
ccracin is offline   Reply With Quote
Old 04-25-2012, 12:59 PM   #15
sgaylord
Project collector
sgaylord's Avatar
Subscribed!
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 04-25-2012, 03:18 PM   #16
robnolimit
robnolimit's Avatar
Chris, check out Speedway Engineering for a rear sway bar parts @ www.speedway1.com I'd use 1 1/4" 48 spline bars and arms. bars are avail in different lengths, 35", 36", 36.5", 37.5", 38.5".... An .095" wall bar is #608-095+length, a .125" wall bar is #608-125+length.
Old 04-25-2012, 08:09 PM   #17
CHRIS67GMC
CHRIS67GMC's Avatar
Here are some pics of the Fat Bar and the Shockwaves being installed. Just tacked everything together to make sure it all fits and works.
Name:  c-10 002 (2).jpg
Name:  c-10 004 (2).jpg
Name:  c-10 005 (2).jpg
Name:  c-10 007 (2).jpg
Name:  c-10 008 (2).jpg
Old 04-25-2012, 08:11 PM   #18
CHRIS67GMC
CHRIS67GMC's Avatar
Name:  c-10 009 (2).jpg
Name:  c-10 010 (2).jpg
Name:  c-10 012 (2).jpg
Old 04-25-2012, 08:18 PM   #19
Tinkermc
I am really enjoying your build looks nice but not as nice as you in your bikini in post 11.
Old 04-25-2012, 08:31 PM   #20
duallyjams
duallyjams's Avatar
I'm digging this.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-25-2012, 10:05 PM   #21
67cheby
67cheby
67cheby's Avatar
Sweet
Old 04-26-2012, 09:18 AM   #22
sgaylord
Project collector
sgaylord's Avatar
Looks awesome. Are you planning to notch the frame at all or do you think you will be low enough without it? What about bump stops?
Steve
Jezebel 3.0 NEW!!!
Roll Tide!
Old 04-26-2012, 01:03 PM   #23
CHRIS67GMC
CHRIS67GMC's Avatar
No notch in the frame we raised the rails 5.5 inches. There will be a bump stop above the axle. It should be 2 inches off the ground aired out.
Old 04-26-2012, 06:20 PM   #24
CHRIS67GMC
CHRIS67GMC's Avatar
Small update put the back brace on the housing. Got most of the panhard bar set up done.
Name:  C-10 001 (3).jpg
Name:  C-10 002 (3).jpg
Old 04-27-2012, 02:55 PM   #25
CHRIS67GMC
CHRIS67GMC's Avatar
Put it on the ground to see how it looks. It will sit about a inch lower when done.
Good view of how far back the engine is.
