Old 04-23-2012, 01:48 PM   #1
estingley
Aux fuel tank color.
1972 C20 with factory aux fuel tank. Does anyone know if it was chassis color or body color? The truck has been repainted in the past so there is a little blue but the rest is road grim and lite rust. I have yet to drop it from the bottom of the bed so maybe that holds my anwser. On the same subject im looking for a original tank selector for the floor. Any help would be appreciated.
estingley is offline   Reply With Quote
Old 04-23-2012, 04:55 PM   #2
Tinkermc
Re: Aux fuel tank color.
they were not painted but could have been undercoated IMHO
Tinkermc is offline   Reply With Quote
Old 04-23-2012, 11:24 PM   #3
SS Tim
SS Tim's Avatar
Originally Posted by estingley View Post
1972 C20 with factory aux fuel tank.... On the same subject im looking for a original tank selector for the floor.
First question, would be are you speaking of the RPO NL2 factory tank? It was mounted on the left side and had a filler extending up and out through the bed. It had a dash mounted selector switch on the far left.
The other would be saddle tanks, these were either GM accessory (dealer installed) or aftermarket. The accessory tanks and most aftermaket used access doors hacked through the side of the bed. These saddle tanks generally used a floor mounted selector typically found beside the seat next to the door. The selector is pretty universal.
Haven't seen a "new" NL2 tank for a very long time but I'd imagine they were the factory tinplate finish.
The saddle tanks I have had were all painted black of some sort.
SS Tim is offline   Reply With Quote
Old 04-24-2012, 11:37 AM   #4
estingley
The tank is mounted on the left side up close to the cab, with a filler extended through the bed side. There is a switch in the dash on the far left. There never was a valve in the floor but it looks like there is a place where one once was. The only reason I asked because the guy I bought the truck from said I needed to find a valve if I wanted to use both tanks. He may not of known either. The glove box sticker says aux fuel tank so I was assuming it was a factory install.
Old 04-24-2012, 12:32 PM   #5
cdowns
cdowns's Avatar
i've never seen a factory painted gastank of any kind in the thousands of different vehicles that i've looked at in detail over the years
Old 04-24-2012, 01:14 PM   #6
Bill72
I believe on the NL2 factory aux tank that the switch on the dash only switched the gas gauge over to the aux tank sending unit and that there was a floor valve to switch the fuel flow. I have never seen one of these tanks painted.
Bill72 is offline   Reply With Quote
Old 04-24-2012, 01:09 PM   #7
estingley
So you believe it was bare steel or undercoated like that frame?
Old 04-24-2012, 03:02 PM   #8
estingley
Any ideas on where to find a original valve? I was told awhile back it was the same valve found in an on chevy straight truck which would make it alot easier to find.
Old 04-25-2012, 08:05 AM   #9
1972RedNeck
1972RedNeck's Avatar
I would try Napa. They probably can't get by application, but I have bought tank selector valves from them.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
