04-25-2012, 03:47 AM | #1 |
Oil pressure sending unit question??
I have a '87 r10 and the PO swapped out the tbi for a 350 crate engine and installed aftermarket gauges. I am going back to the stock setup and have already installed a new oil pressure sending unit but cant find the wire to run it. I did find a brown wire cut off in the wiring harness but when I connected it to the sending unit the gauge still just sits pegged at 60. Any ideas???
04-25-2012, 06:59 AM | #2 |
Moderator
Re: Oil pressure sending unit question??
The oil pressure sender wire should be tan.
Nailing the gauge means you have a shorted sender wire or damaged gauge. |
04-25-2012, 08:42 AM | #3 |
Where does the tan wire run into the wiring harness at? Is there a way I can determine if the gauge is bad?
04-25-2012, 12:05 PM | #4 |
Tore into my harness and found the wire I was looking for and followed it all the way back inside the cab. The PO had then connected the brown wire to the wires that run inside of the drivers door shorting out my gauge causing it to peg out.. Got everything rewired and the gauge now zeros out like it is supposed to and raises when I crank the truck. Havent had a chance to drive it so I dont know if it is correct. When I tap the gauge while the truck is running the gauge will start to give sporadic readings would this be a loose connection?? Thanks for the help..
04-27-2012, 07:19 AM | #5 | |
87' R10 |
04-27-2012, 01:52 PM | #6 | |
Moderator
Straight from the sender ---> Through the Engine/Bulkhead plug ---> Instrument cluster plug. GM circuit #31. For 1987 RV trucks. All other years YMMV. |
04-28-2012, 02:33 PM | #7 | |
04-25-2012, 01:04 PM | #8 |
Moderator
Drive it on a rough road. If the gauge holds don't worry about it. If it gets sporadic check the spring clips in the gauge pod/housing are making contact with the plastic printed circuit and closing on the gauge studs. Make sure the nuts on the gauge studs aren't loose.
04-27-2012, 01:31 AM | #9 | |
This man knows his Chevys Posted via Mobile Device |
04-28-2012, 09:59 PM | #10 |
On the prowl..
87' R10 |
