Window won't go down
I am getting ready to paint my Suburban and removed the wing vents. However, when I closed the door, the window switch got caught between the seats which caused the window to extend all the way up past where it would normally go. Now, I can't figure out how to get the window to go back down. It'll go down about 1/4" and just bind up. How do I get it to go back down?
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
Re: Window won't go down
Unbolt the regulator and track from the door and slide it out of the track it works great I got a set of vent Windows out of a 90 sububan in the junkyard awhile back the Windows were up and no battery I did what I told you and had them out in 10 mins both sides
Posted via Mobile Device |
#3 | |
It's stuck all the way up and can't get it to retract.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift Last edited by Edahall; 04-26-2012 at 12:03 PM. |
It's Probly binding or the roller came out of the track once the glase is out the regulator should go back down
Once I removed the window, I was able to see that one of the arms got caught on the end of a bolt. Simply backing out the bolt freed the arm and I'm back in business.
