Old 04-25-2012, 06:00 PM   #1
tommym
vortech heads
hey guys I have a guestion what is the difference between 350 vortech heads and standard 350 heads
tommym is offline   Reply With Quote
Old 04-25-2012, 06:34 PM   #2
Pro Performance
Pro Performance's Avatar
Re: vortech heads
The vortec have a different bowl design, and use 64CC combustion chambers, which is smaller than most factory chevy heads. That will increase your compression. I used these heads on my square body years ago. They are are good heads for the price.
Be aware, that they require a new manifold, as they use 8 bolts to hold down the intake that go straight down in to the head. And also will need centerbolt valve covers. Some guys will re-drill the heads to accept the traditional style intakes, but even when that is done, the ports don't line up exactly.
I had them on a Goodwrench 350, using a quadrajet, Edelbrock cam (CA smog legal) and headers. It made around 400HP, nothing crazy, but good on the budget.
Pro Performance is offline   Reply With Quote
Old 04-25-2012, 07:37 PM   #3
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: vortech heads
Probably about 100hp
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 04-25-2012, 07:52 PM   #4
tommym
Re: vortech heads
thanks guys so just by useing vortech heads you can pick up a good amount of horsepower
Old 04-25-2012, 08:08 PM   #5
harleyhouser
harleyhouser's Avatar
Re: vortech heads
Be carefull with the amount of lift your cam has. Stock vortec heads have limitations. You have to have them modified to accept higher lift cams. You should post on the engine forum and those guys can give you the specific lift numbers.
harleyhouser is offline   Reply With Quote
Old 04-25-2012, 09:22 PM   #6
hugger6933
Re: vortech heads
Yes the Vortec heads will give you a good increase in horsepower and a modest torque gain as well. I had one in a s1- that ran real good. It is sitting in the corner now waiting for the right truck to come along.
hugger6933 is offline   Reply With Quote
Old 04-25-2012, 11:08 PM   #7
AusTx68
AusTx68's Avatar
Re: vortech heads
Yep, they have a max lift of .487 which isn't much. You can find aftermarkets or have stock ones worked to accept more lift. Mine are capable of .550 max lift. I'm running just over 400 hp with cam specs: .520/.500 Lift 245/245 duration @ .050
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 04-25-2012, 11:21 PM   #8
Pro Performance
Re: vortech heads
I thought Scoggin-Dickey sold the vortec heads already modified with guide plates and new valve springs to accept higher lift cams..... but I couldn't find them. Maybe I have the place wrong and someone else can remember or has seen it.
Old 04-25-2012, 11:34 PM   #9
67c10rustbuket
67c10rustbuket's Avatar
Re: vortech heads
I read that too in car craft I think, That Scoggin-Dickey had them modified for higher lift cams. Good heads either way but much better with more lift capability.
**** BEWARE of trolls selling efi/tbi heads claiming they are "vortec" heads, learn the right casting numbers and visual differences if you are looking for used heads. Some people think any center bolt head is a vortec and they are not, only 1996-98 c/k trucks and later in some suvs through 2000 and vans ?year?
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 04-25-2012, 11:45 PM   #10
AusTx68
AusTx68's Avatar
Re: vortech heads
Here's some good information about Vortec heads and how to identify the casting marks. http://www.chevymania.com/tech/vortec.htm
Summit Racing sells the heads for $278 each. They have a max lift of .520
http://www.summitracing.com/parts/SUM-151124/
Old 04-26-2012, 08:27 AM   #11
tommym
Re: vortech heads
thanks guys yall have been real helpful
Old 04-26-2012, 08:42 AM   #12
Gus350
68 C 10
Gus350's Avatar
Re: vortech heads
I think thats 278 per head not for the pair.
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
