04-26-2012, 03:33 PM | #1 |
Coil spring question
Anyone had good or bad experiences using 3" drop coils with 3" Bell Tech spindles? I have an 87 c-10 1/2 ton running 17".
Thanks for any input. |
04-26-2012, 07:15 PM | #2 |
67-72 parts collector,…
Re: Coil spring question
Some say a 3" drop spring is tough to get the front end alignment correct.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 04-27-2012 at 02:38 PM. |
04-27-2012, 01:34 PM | #3 |
Thanks much.
04-27-2012, 04:07 PM | #4 |
i've heard that with a 3" drop spring if you go over a large bump at speed the spring can cum flying out and your left diggin payvement with whats left of your suspension
04-28-2012, 01:44 PM | #5 | |
If your real worried about that use a limiting strap Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
04-28-2012, 05:28 PM | #6 |
The 3" springs and 3" drop spindles will put the arms real close to the ground. Probably would be fine as stated above, but little too close for me without adjustability like of an air suspension.
But, I bet it looks damn good. |
05-01-2012, 03:24 AM | #7 |
Old member
I have the droped springs in mine and have never had a issue with them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
