Old 04-28-2012, 10:37 PM   #1
JQ-72
JQ-72's Avatar
Tilt Column extravaganza!
5 tilt columns for sale : 2 vans, 2 motor homes and 1 truck. Add $25 each for shipping. Steering wheels will be removed for shipping.
Truck column - Needs a some work. It's a little loose (inner bolts need tightened) and shifter pin hole has some wear. Good wiring. $175
Motor homes - Same shaft length as truck. The linkage arm has a factory bend in it, but can be used as is. They are REALLY nice and tight and came off very low mile vehicles. Notice one has adapter for cruise and intermittent wipers (this can be removed) $225 each.
Vans - 1 is in good condition - $150 ; the other one has wear in the shifter pin area and needs lever - $100
Please reply to thread.
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
Old 04-28-2012, 10:39 PM   #2
JQ-72
JQ-72's Avatar
Re: Tilt Column extravaganza!
truck and vans:
Old 04-28-2012, 10:40 PM   #3
JQ-72
JQ-72's Avatar
motor homes:
Old 04-28-2012, 10:39 PM   #4
HotRod C/10
HotRod C/10's Avatar
in on the truck tilt pending better pics.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 04-29-2012, 11:41 AM   #5
72Blazing
72Blazing's Avatar
Leave some for the rest of us Duane! LOL
72Blazing is offline   Reply With Quote
Old 04-29-2012, 12:09 PM   #6
mcbassin
Still Learning
mcbassin's Avatar
Please put me in line for the truck column. thanks
Old 04-30-2012, 12:32 AM   #7
thecatseye
I'll take the motor home w/out the crusie/intermittent switch if available.
thecatseye is offline   Reply With Quote
Old 04-30-2012, 02:59 PM   #8
thecatseye
PM sent. Thanks Joshua!
Old 04-30-2012, 09:01 AM   #9
JQ-72
JQ-72's Avatar
Heavymetal has backed out so all columns are available. DSALRAM - What else do you need pictures of on the truck column? Mcbassin - your next on the truck.
thecatseye - the motor home column is yours. Sending PM
Old 04-30-2012, 02:38 PM   #10
HotRod C/10
Is the column repairable with whats there or are new parts needed?
LS SWAPPED
-1976 SILVERADO
Old 05-02-2012, 08:44 AM   #11
JQ-72
JQ-72's Avatar
One motor home SOLD to thecatseye.
DSALRAM - The bolts can be accessed and tightened, just takes a little time. As for the shifter pin hole, I've heard of people filling with JB Weld and smoothing out. It is functional now, there's just some play in the shift lever. Besides that, just needs cleaned and repainted. Could use new levers (available aftermarket).
JQ
Old 05-02-2012, 06:57 PM   #12
Crash_OK
Crash_OK's Avatar
Please put me in line for the truck tilt... Thanks..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 05-02-2012, 07:53 PM   #13
HotRod C/10
JQ
Thanks, I'll pass
LS SWAPPED
-1976 SILVERADO
Old 05-02-2012, 08:23 PM   #14
JQ-72
JQ-72's Avatar
mcbassin - You are up for the truck tilt. LMK
JQ
Old 05-02-2012, 10:14 PM   #15
mcbassin
Still Learning
mcbassin's Avatar
JQ
JQ,
Which one of the above picture(s) are of the truck tilt? I know you said it needed some bolts inside tightened up, that's no biggy, what about the hole that is wore out? which picture is it? Pretty sure I can fix that too. Just want to be clear on which one is the truck tilt. What other new parts will I need to make this ready to install? thanks
Old 05-02-2012, 11:34 PM   #16
JQ-72
JQ-72's Avatar
Look at the 2nd post with "truck and vans" as a heading. The truck column is pictured in the first 2 pictures, the second being the shifter pin hole. This column was pulled from a running 72 Cheyenne. Again, the main thing it needs is just cosmetic stuff - new levers, fresh paint. It has good wiring, bearings seem OK. I think the cancelling cam may have a crack where the signal lever attaches.
Joshua
Old 05-03-2012, 08:12 AM   #17
mcbassin
Still Learning
mcbassin's Avatar
Joshua
Thanks Josh, I'll take it. Hopefully it won't be a big deal for a rookie
PM payment instructions. thanks,
Mike
Old 05-03-2012, 07:33 AM   #18
daddymoo2
JQ-72: Put me in line on truck tilt. I will take it at 175.00 shipped. Don
daddymoo2 is offline   Reply With Quote
Old 05-03-2012, 10:53 AM   #19
mcbassin
Still Learning
mcbassin's Avatar
Payment sent thanks Josh.
Old 05-04-2012, 08:20 AM   #20
JQ-72
JQ-72's Avatar
TTT - still some available.
Old 05-21-2012, 08:56 PM   #21
MidWest72C10
what do you have available?
Scott
Daily Driver:2010 Z71 Ext Cab
Project:1972 C10 SWB
MidWest72C10 is offline   Reply With Quote
Old 05-21-2012, 09:27 PM   #22
JQ-72
JQ-72's Avatar
I'm down to the van tilts.
JQ
Old 05-21-2012, 10:13 PM   #23
VA72C10
VA72C10
VA72C10's Avatar
ttt
Old 05-22-2012, 08:32 AM   #24
JQ-72
JQ-72's Avatar
Van tilt is good and tight - just needs cosmetics. New paint and possibly new levers for high point show, scouring pad for driver! I'll PM payment info. Thanks.
Joshua
Old 05-24-2012, 01:35 AM   #25
VA72C10
VA72C10
VA72C10's Avatar
ttt for you
