04-29-2012, 02:42 PM | #1 |
Robert Olson Transport
What did you get done 4/29/12 edition
We went to a couple of more shows ... other than that not much.. gave her a good cleaning and bought stuff fo an oil change ... You all?
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
04-29-2012, 04:13 PM | #2 |
Re: What did you get done 4/29/12 edition
well i didnt get anything done this weekend i have been feeling pritty bad. friday the dr wanted to put me in the hospital but i elected to go home insted. i hope to get my engine bay finished this week. i can pick up my driveshaft wed so i hope to frive my truck to the cruize in sat night. all 5 or 6 colors of her lol
most people sleep peacfully at night because, rough men stand ready to do violenceon there behalf. |
04-29-2012, 06:09 PM | #3 |
Painted the fog light mounts on my grill and the mounts that hold it to the truck and all behind it a silver "hammered metal" color, looks pretty good and ill try to get pics posted, I never see grills like mine so wanted to clean it up insted of replace
Posted via Mobile Device |
04-29-2012, 06:13 PM | #4 |
Right in front of you.
Got my T chassis in a rolling state.....
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A |
04-29-2012, 06:43 PM | #5 |
Finally took care of two nagging issues. 1) fixed the loose glove box lock mechanism using a paper clip to remove and then loctite before tightening back up.....tired of it flopping open everytime i go over the railroad tracks in town and 2) cleaned the stock radio power/speaker plug ins on the back of the radio...had to pull the ac plenum to get at it....no more radio cutting out/static when going over the same railroad tracks
It's the little things getting fix that make driving my truck just a little nicer Posted via Mobile Device
_______________________________________________ 1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger" 1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel |
04-29-2012, 10:03 PM | #6 |
Square
so now you can trade me for my truck?
Squarebody Syndicate |
04-29-2012, 06:47 PM | #7 |
6.0 powered square
took the truck to the track ran my first ever pass at 13.77 at 98mph in the 1/4 with tire spin third pass ran a 13.69 hooked good, fourth pass spun sideways to 60ft and coasted down the track at a 16.8 at 83 mph
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
04-29-2012, 07:00 PM | #8 |
I got my exhaust welded on and also took her out for a drive for the first time. Def made all the hard work and money worth it. Also attempted to fix my brake problem. The brakes work but u have to pump at least once for them to kick in. I have replaced every piece in the brake system itself and still is doing it. I'm lost on what to do next. Will post video of trick with exhaust later this evening.
04-29-2012, 09:25 PM | #9 |
Installed a new water heater...in the attic. I hate whoever decided to put it up there when they built the house.
04-29-2012, 09:48 PM | #10 | |
here is a quick video i did with my phone of the new exhaust |
04-29-2012, 09:27 PM | #11 |
Behind my grill half done
All done Posted via Mobile Device |
04-29-2012, 10:10 PM | #12 |
Painted brackets and hung tanks...
04-29-2012, 10:11 PM | #13 |
Replaced ALL the em brake cables, pulled grille out, all the trim off, ft bumper off, rear bumper off, all the wood & metal out of the bed.
04-29-2012, 11:31 PM | #14 |
Installed drop spindles and reattached swaybar. Did a full service on the rear diff and transmission got new pan gasket, filter and rear seal. Then I fitted up my new fuel tank to see how it fit. Need to still fab some brackets tho.
04-29-2012, 11:44 PM | #15 |
Project Clean:
I promptly removed the first layer of fall/winter dirt, vacuumed out the interior and cleaned the glass somewhat. Many more layers to go I’m sure.
Sit back. Relax. Enjoy the ride! 86 Chevy Scottsdale C20, SBC 350, TH400, 4.10 gear ratio |
04-30-2012, 12:49 AM | #16 |
Not a thing....I lazied around all weekend!
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
04-30-2012, 01:12 AM | #17 |
Got my brother to help me remove the front clip. Should be a heck of a lot easier to work on the truck now |
04-30-2012, 01:03 AM | #18 |
Caught a fuel leak late last weekend - turned out to be a rubber hose between fuel pump and high pressure filter was rubbing against wire harness in the frame rail! Re- routed the harness. New SAE 30R9 hose and new fuel filter took care of this potentially dangerous situation. Did not get a chance to drive it - too many other projects.
//RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
04-30-2012, 08:45 AM | #19 |
I went out early Sunday morning and acquired some spare parts for a raining day. I think I’m becoming a 73-87 parts hoarder!
Snagged a whole interior minus steering column and dash. Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
04-30-2012, 09:13 AM | #20 |
Always a work in progress
I got a shipment of parts in for the truck, gotta love summit, ordered on thursday and on my front porch Saturday afternoon(No Saturday delivery fee!!). I also went to the junkyard and got a set of springs so I can rebuild them and get rid of the chevy lean. Got a free hood to replace the one I junked, it is very straight and rust free. Got the passenger side exhaust tacked up and just need to finish weld it. All in all not a bad weekend.
Just a quick shot of the engine bay!!
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
04-30-2012, 03:15 PM | #21 |
I spent the weekend drilling out spot rivets and replacing the core support on my daily driver. Maybe after its over I'll clean the garage and pull the ole' chevy in for the teardown.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
04-30-2012, 03:22 PM | #22 |
I broke my truck, the spent the day trying to fix it. I can now time a SBC. I also painted my front end chrome black to try and cover up the pitted and generally nasty chrome. Not sure I like it much though.
79 Blazer 350 TH350 part time 4wd Sold! 86 GMC 1 ton something... |
04-30-2012, 03:56 PM | #23 |
Insert Witty Text Here
My truck stranded me a block from the house Saturday for the first time in the eleven years I have owned it. No spark. An acquaintance who was in the area towed me home with his '48 Ford F1!
I replaced the module in the HEI yesterday, but still no spark. I'll keep at it later in the week. Slonaker |
04-30-2012, 08:29 PM | #24 |
78K & 79C Jimmys
Moved our trailers,yard work up there
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
