Old 05-01-2012, 03:11 PM   #1
l885762
six speed swap?
Looking for information on swapping a six speed manual transmission in a 1982 1 ton srw chevy 4x4. Truck has a 502 bb with a factory 4 speed and 205 transfer case. Has anyone done the zf 6 speed swap or maybe a 5 speed swap. Just trying to get the facts on doing it right. Might be talked into an automatic overdrive also but I really would rather stick to the stick. Thanks in advance.
l885762 is offline   Reply With Quote
Old 05-01-2012, 05:51 PM   #2
legendman
legendman's Avatar
Re: six speed swap?
A NV4500 5sp is a pretty easy swap almost a direct bolt-in.
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 05-08-2012, 06:58 PM   #3
x ReAcT x
Re: six speed swap?
how much modification would be needed to instal a nv-4500? I have an 86 gmc with the same exact setup he does. 4 speed with granny gear and a 205 transfer case.
1986 GMC K15 4.3V6/SM465/NP205
will be converting to
5.3LS E-ROD/AA adapter/SM465/NP205
10 Bolt Axle Rebuild Tutorial:
http://67-72chevytrucks.com/vboard/s...d.php?t=536415
x ReAcT x is offline   Reply With Quote
Old 05-10-2012, 05:11 PM   #4
x ReAcT x
Re: six speed swap?
Correction i have a 208 transfer case
Old 05-10-2012, 06:08 PM   #5
l885762
Re: six speed swap?
What is the difference in a 205 and 208 transfer case?
Old 05-10-2012, 09:52 PM   #6
x ReAcT x
Re: six speed swap?
From what ive read the 205 has gears that directly connect rather than the 208 which has a chain which connects the shafts
Old 05-01-2012, 05:53 PM   #7
l885762
Re: six speed swap?
Thanks ledgendman,
You don't happen to know the year truck I want one out of do you? It will fit the 205 transfer case also?
Old 05-01-2012, 05:57 PM   #8
legendman
legendman's Avatar
Re: six speed swap?
91-to some year I forgot, the later ones are better but the early ones had a lower first gear.
Hope it's ok to post this here, thread on one in a k30 with a 6.2 diesel
http://www.dieselplace.com/forum/sho...ghlight=nv4500
Old 05-01-2012, 06:09 PM   #9
l885762
Re: six speed swap?
Thanks for the thread. I think I can learn most of what I need from it. Any knowledge on the newer six speed?
Old 05-01-2012, 07:03 PM   #10
legendman
legendman's Avatar
Re: six speed swap?
NP
No info on the 6sp, only did research on the nv4500 because of the availability.
Old 05-01-2012, 11:55 PM   #11
my4by2
my4by2's Avatar
Re: six speed swap?
I wanted to originally go with a ZF 6-speed in my truck but it became a royal pain trying to get it all together - let alone find a good donor trans assembly... My recommendation is to do what I did - just stick with an NV4500 5-speed - easy to find & easy to swap!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 05-02-2012, 09:32 AM   #12
l885762
Re: six speed swap?
Thanks to you both, I will probably do just that. Will start looking for the nv-4500. Thanks again.
