Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-03-2012, 02:49 PM   #1
coop34
Intermittent Blinkers
Having a blinker problem. They will work fine for a week or so, and then just stop working. Eventually after a few weeks they will suddenly start working again, only to stop working a week or so later. Any suggestions??
coop34 is offline   Reply With Quote
Old 05-03-2012, 03:51 PM   #2
RAS C-10
RAS C-10's Avatar
Re: Intermittent Blinkers
Far from an expert on this or as a matter of fact anything... but to me it sounds like possibly a short, maybe an exposed wire randomly touching metal shorting it out or something.
Just my $.02
If you think nobody cares if you're alive, try missing a couple of payments.
RAS C-10 is offline   Reply With Quote
Old 05-03-2012, 03:57 PM   #3
coop34
Thanks for the suggestion. I'll look into that.
Old 05-03-2012, 04:44 PM   #4
old Chevy guy
old Chevy guy's Avatar
Do they light and not blink or do they they not light up either? Could be the flasher relay or bad conection in the fuse box. Bad grounds acount for the majority of light problems. Give us more info.
old Chevy guy is offline   Reply With Quote
Old 05-03-2012, 04:51 PM   #5
davepl
davepl's Avatar
Try wiggling the hazard switch. From what I remember before my truck was part, if you hold the harzard switch in part way it stops the signals and blinkers from working (they come on, but do not flash). And since the hazard switches tend to go bad, it's an easy check.
Next up would be the relay can (the flasher). Cheap and easy to replace.
After that you're looking at the signal light switch and the wiring, but the first two are easy to check.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-03-2012, 04:59 PM   #6
coop34
They don't turn on at all and the flashers don't click. The flashers and turn signal switch are only about 6 months old.
Old 05-03-2012, 05:05 PM   #7
old Chevy guy
Get a test light and probe in the fuse box and see if theres power on both sides of the fuse when the lights dont work. Do the brake lights work fine?
Old 05-03-2012, 05:09 PM   #8
coop34
I'll have to check the brake lights when I get home tonight.
Old 05-03-2012, 06:15 PM   #9
coop34
Went to check to see if they brake lights work and what do you know the blinkers are working again! Of course they start working when I'm ready to test out a few things. Guess I'll have to wait a week or so for them to stop working again!
Old 05-03-2012, 09:36 PM   #10
Kidd-7
Kidd-7's Avatar
Check the light contacts, can't remember how the connections are made in these trucks, but I've had a few newer vehicles lately that have had corrosion on the contacts causing the lights to work intermittently.
71 C-10 - 307 - 3 on tree
01 Ford Explorer 5.0 v8
96 Mercury Cougar v8
79 Trans Am 403 Olds
Kidd-7 is offline   Reply With Quote
Old 05-04-2012, 12:27 AM   #11
old Chevy guy
That part of why I wondered about the Brake lights,they use the same wiring and filaments as the rear blinkers.
Old 05-04-2012, 11:49 AM   #12
coop34
OldChevyGuy - Checked last night. The brake lights do work when the blinkers aren't. Does that rule out some things?
Old 05-07-2012, 11:53 AM   #13
coop34
The brake lights work, but when I put on the blinkers, they go out?
Old 05-08-2012, 11:51 AM   #14
fixit-p
fixit-p's Avatar
Do both brake lights go out or just the one on the side the blinker switch is set to, also when the blinkers don't work does the indicators on the dash light up?
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 05-09-2012, 12:42 PM   #15
coop34
fixit-p: Just one side of the brake lights goes out when the blinker is turned on, and no the indicators on the dash do not light up.
kidd: The hazard lights work fine.
Old 05-07-2012, 09:02 PM   #16
Kidd-7
Kidd-7's Avatar
Are you saying the brake light go out when the blinkers are turned on? Do they act any different with the hazard lights?
Old 05-07-2012, 11:41 PM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
Probably low on blinker fluid.
Sorry, but I couldn't resist...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-08-2012, 06:15 AM   #18
panhandler62
Java Mechanic
panhandler62's Avatar
I was going say that it's normal for blinkers to be intermittent ... on ... off ... on ... off...
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 05-08-2012, 11:35 AM   #19
coop34
Ha Ha! I'll check the fluid tonight, and while I'm at it, I'll check the muffler bearings.
Anyway still have the blinker problem. Blinkers don't work. Brake lights do, until I turn on a blinker. Not sure about the hazard operation. I'll check that out tonight. Thank you all for your help and your laughs at my expense.
