Steering Column Help
Under the hood on the steering column what is the part called that the column rotates and lands onto when shifting. This is worn out in my truck and its causing me gears to slip into another gear, from reverse into drive and also wont hold second? Please and thank you.
Restoration Virgin!
Re: Steering Column Help
ttt
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
![]() Join Date: Jan 2012
I believe it is called the selector plate.
The truck my son and I are redoing had the same problem. The plate's tabs or tangs were extremely worn down. So badly if you slammed the driver's door closed the shifter would drop from park to reverse. Not good. Rather than finding a replacement or having it rebuilt, we opted to upgrade to a rebuilt factory tilt column.
Cheers - Wayne Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966 '55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157 1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy" 1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55 Nothing sucks more than that moment during an argument when you realize you're wrong. |
#4 | |
Restoration Virgin!
It brings your thread back to the top of the forum so others that may not of read/ seen it can read and hopefully provide some help.....we also use 'bump' as well....
Okay thanks
