Old 05-04-2012, 10:54 PM   #1
muleys67
Post cutting the frame
Recently I watched "Car Warriors" with 2 72 C10 trucks. One team shortened the frame,longbed to shortbed. Then the other day I saw on Velocity channel, Lou and Jared did the same thing. On both shows the frame was cut in one vertical pass. I thought the correct way is to make an "ell" shape cut thereby making the joint stronger when welded.Im sure Ive seen this info before.The reason Im curious is I am thinking of shortening my 69 c30 to make a dually pickup.Any thoughts? Muley
muleys67 is offline   Reply With Quote
Old 05-04-2012, 11:40 PM   #2
dv8customs
dv8customs's Avatar
Re: cutting the frame
Straight cut is fine, no reason to do the "L" cut method.
dv8customs is offline   Reply With Quote
Old 05-05-2012, 12:30 AM   #3
FnLow69
FnLow69's Avatar
Ya i would say it doesnt matter as long as it properly welded and plated. Doing the "L" method might help make sure the frame is in proper alignment.
FnLow69 is offline   Reply With Quote
Old 05-05-2012, 04:15 AM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
The L shape is preferred cause if a crack was to form along the weld the L should terminate it going further, this being as long as you radius the 90* corners on the cut. The added bonus is you have more weld holding together and better alignment.
While a straight cut is fine with reinforcing a renforced L would add more peace of mind if your worried
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-05-2012, 08:15 AM   #5
GMtrucknut!!
GMtrucknut!!'s Avatar
Either way will work it takes a little more time and measuring to use the "L" method But with either I still reinforce the frame.
GMtrucknut!! is offline   Reply With Quote
