Old 05-05-2012, 05:27 PM   #1
rubberbandit
Active Member
rubberbandit's Avatar
Rebuild front calipers or get new ones?
wondering if I should just buy a kit and rebuild my front calipers or if I would be better off buying a pair instead. Is there anything wrong with stock calipers? I will have new pads and rotors but am wondering if I really need to buy new calipers. (see truck details in signature)
Thanks in advance
-Chad
'72, C10, SWB, fleet, 4L80E, 406sbc, EFI, TruTrac Blackfoot
'69 C20 Suburban, PB Dropmember, 3rd row, LS3 6.2L, 4l80e, rear A/C, Dakota Digital HDX Babe: The Blue Ox
rubberbandit is offline   Reply With Quote
Old 05-05-2012, 08:50 PM   #2
AirSpeed
AirSpeed's Avatar
Re: Rebuild front calipers or get new ones?
I would just buy rebuilt calipers, they're cheap! My last pair cost about $35 each.
AirSpeed is offline   Reply With Quote
Old 05-05-2012, 08:59 PM   #3
izazzel
its not usally worth the head ache to rebuild the ones you have for the diff in the cost to get new ones
izazzel is offline   Reply With Quote
Old 05-06-2012, 10:29 AM   #4
slikside
slikside's Avatar
If you don't want to do the rebuild work yourself, using your existing calipers as your cores will be the least expensive way to go. I think Orielly's has them for about $21-23 apiece with core exchange. I believe they are Cardone remans.
I was going to go that route, but in the end I didn't want to surrender my original calipers, or pay more for the Cardones, and have mine laying around.
I had a shop rebuild mine for about $40 each. So it's definitely not the cheapest way to go. I also had them rebuild/replate my booster, the master cylinder, and prop valve.
But if you were to do the work yourself, I think you could just about do it for the same, or less than the Cardone route.
I don't think a "new" caliper will perform any better than a properly rebuilt original (assuming we are comparing stock to stock....no wilwoods or ssbc's etc.) It's just a chunk of metal that holds fluid to push a piston. But if you do decide to rebuild your own, make sure the piston is not pitted where it contacts the seals, and don't forget to replace the bushings where the mounting bolts slide through, along with the o-rings in there. If it doesn't float right, it won't work right.
slikside is online now   Reply With Quote
Old 05-06-2012, 11:00 AM   #5
Wrenchbender Ret
I have been rebuilding them for many years. You need a special tool to seat the boot. If you are just going to do it once I would get the remans. You have to make sure the bleeder valve does not break off before you rebuild one.
Wrenchbender Ret is offline   Reply With Quote
Old 05-06-2012, 01:55 PM   #6
72chevyk10
I built it
72chevyk10's Avatar
all ive ever done for calipers is put the whole thing in the vice to squeze the piston back in to fit new pads. works just like new
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 05-06-2012, 03:03 PM   #7
davepl
davepl's Avatar
Can you expand on seating the boots? I'm about to rebuild mine (because I want to keep the originals with the GM logo, etc) and have never done it, so any tips would be appreciated.
Like most things, the special tool helps but may not be required (ie: there's another way to do it). Any way to seat the boots without a special tool, or if not, is this a common thing I can grab at an auto parts store or is it super-special and expensive?
Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
