Old 05-06-2012, 10:13 AM   #1
77chevyinline6
77chevyinline6's Avatar
Help me find out what this piece is called please.
250 inline 6 1 bbl it screws into the side of the carb and the guy who rebuilt my carb told me it was bad it has something to do with the idle so i need to find another one i just dont know what this is called please help. Thanks.
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor)
350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator.
77chevyinline6 is offline   Reply With Quote
Old 05-06-2012, 12:57 PM   #2
rustyMUD
Re: Help me find out what this piece is called please.
That would be the "idle stop solenoid". When you turn the key to "on" the solenoid receives current and a plunger sticks out to bump up the throttle. When you shut the vehicle off, the solenoid retracts the plunger, allowing the throttle plates to fully close and prevent dieseling.
Mine was bad on the Monojet for my 292. I went to my local carquest and asked for a new one. They wanted 387 dollars for the idle stop solenoid. I rigged up a bolt on the carb that keeps the throttle bumped up a bit to provide a steady idle, but not so far as to make the engine diesel when shutting it off. This seems to work well and was essentially free.
rustyMUD is offline   Reply With Quote
Old 05-06-2012, 01:46 PM   #3
beamn7
Bingo on the description!
GM part numbers: 7043575 or 17067963
Standard Motor Products: ES25
Readily available:
http://www.google.com/#sclient=psy-a...w=1010&bih=531
beamn7 is offline   Reply With Quote
Old 05-06-2012, 02:22 PM   #4
csb#356
You should test it out and make sure its bad before replacing, because if the guy that rebuilt your carb didn't know what it was called and just said its bad that sounds kind of suspect to me. But then again I'm always picky about knowing why something is "bad", especially for the price the guy above mentioned.
csb#356 is offline   Reply With Quote
