05-10-2012, 05:17 PM | #1 |
Reversing towing wheelbase rule of thumb?
There is a towing wheel base rule thumb that a 110" wheelbase can tow a 20' trailer and then you can add 1' of trailer for each additional 4" of wheelbase.
I have a 4,000 lb camping trailer that is 16'6" from bumper to tongue hitch. Is it safe to reverse the rule of thumb and conclude that: 20' - 3' = 17' So 110" wheelbase - (3' x 4") = 98" wheelbase would suffice. Which means I could tow my trailer safely with a Blazer which, I think, have wheelbases of around 104". Does this seem safe? Posted via Mobile Device
Old Smokey: 85 GMC 3/4 ton long bed crew cab originally a 5.7 gas engine now with an 84 6.2 with a 92 serpentine belt system, a banks sidewinder, torque converter, and a shift kit. I bought her this way from someone handy - and now am trying to figure out how all this truck works. The Old Smokey project: http://67-72chevytrucks.com/vboard/s...d.php?t=390518 |
05-10-2012, 09:46 PM | #2 |
I know the pieces fit
Re: Reversing towing wheelbase rule of thumb?
I've had a few and towed with them a good bit. There's no making up for that short wheelbase, 1.5 inches shorter than a 79 Z28. It will push if you brake too hard and it will whip if you change lanes too quick. Drive with that in mind and it'll do OK at that length.
05-11-2012, 02:20 PM | #3 |
Ok. Thanks. Sounds like in an ideal situation I'd havea blazer that was a little longer.
05-13-2012, 12:17 PM | #4 |
im generally pretty ignorant about squares, although i love em. i don't know what the wheelbases are, etc.
i towed my 18' bass boat, which probably has near a 20' trailer. it's an 88 ranger which isn't known to be light. it has a 175 johnson on it. i don't know what it weighs. my 85 shortbed pulled it great! it didn't seem to push bad, although it did sway a little. i blamed that for the heavy outboard over the back of the trailer though. to be fair, i drive pretty conservatively. i don't accelerate or brake real hard. (well, okay. i accelerate hard every now and then, but not pulling the boat!) |
05-13-2012, 03:58 PM | #6 |
wow, 11 inches is a lot. i never realized there was that much more! i'd have guessed a few at most!
05-13-2012, 10:02 PM | #7 |
I own a 1976 20' Komfort Travel Trailer that I tow with my K5 often. I have no idea how much it weighs, but its at least 4000+ lbs. I am running a Class III hitch with a digital trailer brake controller. I have ZERO issues with sway or 'pushing', even with a 20 mph crosswind.
I am converting to 2wd right now and considering added a sway-control type attactment, but I'll wait until I have problems before fixing a problem I don't have.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
