Old 05-15-2012, 09:34 PM   #1
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Steam Line help...
I'm trying to figure out the best place to drill and tap for the steam line fitting in the new water pump for my 5.3. I've seen most tap into the "bubble" near the upper neck (mine has no bubble), and also have seen some tap into the water neck on the thermostat housing... What do you guys suggest with the Pump pictured below? Name:  5.3 Water Pump.jpg
Name:  5.3 Water Pump 2.jpg
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 05-15-2012, 09:53 PM   #2
clinebarger
Re: Steam Line help...
Route it to the radiator tank like GM intended, Drilling a hole in that new water pump will void the warranty.
Any good radiator shop can solder a 3/8" brass hose barb in the tank, Im guessing your using the original Brass/Copper radiator?
clinebarger is offline   Reply With Quote
Old 05-15-2012, 09:56 PM   #3
JNJchev77
Registered Cruiser
JNJchev77's Avatar
I will be using a new alum rad., elec fans. Should I just have them add the fitting when ordering then??
77' Chevy SB
5.3/4l60e combo
Old 05-15-2012, 10:34 PM   #4
TR65
TR65's Avatar
I got a Griffin radiator this week for my 65. It is set up for LS engines with the 1-1/4 inlet moved to the passenger side and 1-1/2 outlet. It came with a 1/8" pipe bushing welded into the top tank for the steam line. The LS1 book put out by GM says to route the steam line to the highest point in the coolant system, top of the radiator tank.
Good luck,
TR
PS My Champion radiator puked on me.
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 05-15-2012, 11:14 PM   #5
clinebarger
I think fancy aluminum radiators are over rated, SBC-A/C squares have good stock 3-row radiators. BBC squares have a really good 4-row radiator.
Yes, you can order a aluminum radiator with provisions.
Old 05-16-2012, 12:20 AM   #6
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Thanks for the reply's, big help guys!
77' Chevy SB
5.3/4l60e combo
Old 05-18-2012, 10:12 PM   #7
mooseknuckles
mooseknuckles's Avatar
I drilled mine on the back of the water pump outlet....
mooseknuckles is offline   Reply With Quote
Old 05-24-2012, 03:05 AM   #8
BigDan3131
BigDan3131's Avatar
Are steam lines only needed on fuel injected engines or on a carbed motor too?
BigDan3131 is offline   Reply With Quote
Old 05-24-2012, 08:31 AM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
Induction is of no consequence. The LS cooling system needs to be able to purge steam pockets. Since there is no coolant in the intake, the highest point of the system is the front of the cylinder heads; steam lines give it place to evacuate.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-24-2012, 09:26 AM   #10
66ChevyMax
66ChevyMax's Avatar
I took my aluminum radiator to the shop and had them add a 1/4" nipple to the top tank.
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 05-24-2012, 11:45 AM   #11
OneOffStroker
I drilled and tapped the top of my pump, about 1" to the right of the outlet. See pic in post #18 http://www.67-72chevytrucks.com/vboa...d.php?t=520516
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
