Old 05-17-2012, 06:32 PM   #1
felon c10
?distance from cap to block
Can anybody tell me what the distance from the cap to block is on a sbc 350 roller.not really sure if its 2.6416 thanks
felon c10 is offline   Reply With Quote
Old 05-18-2012, 10:22 AM   #2
felon c10
Re: ?distance from cap to block
Bump anyone?
Old 05-18-2012, 10:31 AM   #3
rfmaster
rfmaster's Avatar
Do you mean the from distributor mounting flange (intake manifold) to the base of the distributor cap mounting flange on a stock large hat HEI???? You need to pose questions a bit clear....
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 05-18-2012, 02:58 PM   #4
felon c10
Sorry. From the main caps where the crank sits I need to know if I have to line bore before I put the crank bearngs
Old 05-18-2012, 06:23 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
There is a special tool for measuring if your main cap bores are out of alignment. You can also tell if your main. Bearings are wearing unevenly. Usually if I have to line bore an engine I also go and torque plate hone and square deck and bore to the crank centerline.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
