Old 05-19-2012, 04:57 PM   #1
rvp183
help with fuel filler
Help please,
I have relocated the tank to spare tire location. I need a creative solution to the filler neck and cap which is currently flopping around in the hole cut in the bed. (rear drivers side at inside corner of wheel well) I need a several inches so fuel doesnt splash back from the elbow when fillling..Im thinking a custom box of some sort, or if anyone has found a filler door, cap, neck combo that would work I'd love to see what you have done.
1972 Highlander...thanks in advance!:
rvp183 is offline   Reply With Quote
Old 05-19-2012, 08:34 PM   #2
thelonerife
thelonerife's Avatar
Re: help with fuel filler
I had a buddy make a box that I put the stock rubber grommet in and the neck through. like stock. The top of it was at a 45 degree angle and the box was like 5'' square. I don't have any pics sorry. I liked it but I added a vinyl bed cover w/ aluminum frame and snaps. I didn't like un snapping it every time I filled up.
thelonerife is offline   Reply With Quote
Old 05-19-2012, 11:22 PM   #3
RexDodge
Find yourself a donor, late 80's chevy pick up or suburban, and scavenge the fuel door, hose and vent hose. They fit perfectly. Easy peazy...
RexDodge is offline   Reply With Quote
Old 05-19-2012, 11:45 PM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Hart_Rod's idea...
http://67-72chevytrucks.com/vboard/s...el+filler+idea
I kinda used his idea.
http://67-72chevytrucks.com/vboard/s...382181&page=20
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 05-20-2012, 09:26 AM   #5
Eddie H.
Eddie H.'s Avatar
I used a 45 degree marine filler neck and made a little enclosure for it tucked just inside the bed.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 05-20-2012, 10:39 AM   #6
elf w/capital T
aw man thats rad! i like it!!
elf w/capital T is offline   Reply With Quote
Old 05-20-2012, 09:38 PM   #7
crushermechanic
crushermechanic's Avatar
This is mine. Put it behind the backup light. It works great and have no problems filling.
crushermechanic is offline   Reply With Quote
Old 05-21-2012, 01:00 AM   #8
kevmcrae
kevmcrae's Avatar
My tank and filler are from an 80's Blazer. Think the cover/wedge came from the same rig. I cut it in half width wise and added about an extra 2-3 inches to extend it after I welded in the mid 90's Chevy fuel door. Filler hose fits nicely between the frame and bottom of the bed.
kevmcrae is offline   Reply With Quote
Old 05-21-2012, 01:51 PM   #9
coop34
Check out the project silver dollar build. mrhino had a pretty discreet option for a filler. I also did this on mine and I like how it looks, although I think I need to play around with the slope of the lines as it is slow filling.
coop34 is offline   Reply With Quote
please help
