05-20-2012, 08:25 PM | #1 |
House Plumbing - water leak
Gentlemen -
I'm on about my 4th or 5th iteration trying to fix this plumbing leak. The situation is related to an outside hose bib; there's a section of black flexible pipe, which transitions to a white plastic push in fitting, then to the copper. It's leaking right at the black pipe/push in fitting. First thing I noticed was the old hose clamp was rusty and nasty, so I cut it off and replaced it with a new clamp and torqued it down. No good. Next up - let's try TWO hose clamps, right? No good. So - somewhere in there I decided to try the copper colored permatex RTV and let it set up overnight (24 hours) - still no good. What's the professional way to fix this? Do I need heat to soften up the black plastic?
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-20-2012, 08:32 PM | #2 |
Re: House Plumbing - water leak
Can you try to cut of some of the end of the black pipe and re-install everything to it? Maybe its cracked on the bottom side, out of sight.
I hate plumbing.
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
05-20-2012, 11:00 PM | #3 |
Disclaimer first I am no professional plumber just grew up poor in the hog business and messed with lots of that black pipe.
Your best bet is if you have enough black pipe cut off an inch or two and heat it then 2 hose clamps also if you can put a brass barb fitting in instead of the white plastic I usually got along better. Seems after time the plastic ones crack and the fitting will leak over time.
Clint Youse Paris, MO 1984 Chevrolet 3+3 K30 with Cummins 1966 IH Scout has been a work in progress for 16 yrs |
05-20-2012, 11:22 PM | #4 |
like above said u should have a barbed fitting/adapter for the black tubing try the sprinkler area
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
05-21-2012, 09:06 PM | #5 |
Yep brass.
05-21-2012, 09:09 PM | #6 |
Definately brass, plastic doesn't dig i.to the plastic pipe and always end up being the culprit. Look at shark bite fittings also, i do not know if they are intended for underground use though.
1978 GMC K25 2002 Dodge Dakota R/T rc swb In need of some more goodies. |
05-22-2012, 09:10 AM | #7 |
Looks like we have a concensus. Brass it is.
Thanks, guys! K
05-23-2012, 12:36 PM | #8 |
Yellow truck club
Yes cut it back if you can add a brass fitting and a bit of heat before using 2 clamps.
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
