Sea foam ??
Has anyonne put sea foam in your oil ???
Posted via Mobile Device |
Re: Sea foam ??
I did Then my motor was never the same, it didn't smoke before but it does now and bad worse mistake I made. I have heard people like it but I would never use it again. But it made me start my restore
Getting Old; Going Broke
Re: Sea foam ??
Directly in to the oil fill, no. Ran it thru my intake and put some in the gasoline in my 79 K5 that had a 400 in it. Made it smoke like a bonfire for 20 minutes or so but then never again. Really smoothed out the idle and just in general made it run a lot better.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Sea foam ??
i used it on my motorcycle to clean up a lousy idle and it worked there i dont think id throw that in the oil..
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: Sea foam ??
I've had good luck using it in oil in older engines to free stuck lifters, loosen varnish, etc. I just add it to oil and let it run for 30 min. or so and then dump and add new oil/filter.
Re: Sea foam ??
if i was you i would not add it to oil. if you want to use it start the truck and pull a vaccum line and put the hose in the sea foam it will clean intake runners and valves. i may would dump some in the gas but thats it
most people sleep peacfully at night because, rough men stand ready to do violenceon there behalf. |
![]() Join Date: Oct 2011
Re: Sea foam ??
I also wouldn't put it in the oil... but I've poured it into carbs and fuel tanks and had it really smooth out an engine.
I love it for a rough idle.
1987 R10 1976 K10 |
Re: Sea foam ??
I didn't know you could add it to oil, only used it in the fuel, and you need to have a new fuel filter ready when you do use it cause it will plug up in no time. Just my .02
"Fork: an instrument used chiefly for putting dead animals into the mouth." - Ambrose Bierce 1982 Chevy K30 |
