Old 05-22-2012, 04:34 PM   #1
1moretoy
tail lights
what is needed to install the tail light assembly on a 70 short fleet. is there some kind of brackets or anything. i converted my bed from a step to fleet so i have know idea what i need. thanks. maybe someone can share a photo. thanks
1moretoy is offline   Reply With Quote
Old 05-22-2012, 04:39 PM   #2
BMERDOC
BMERDOC's Avatar
Re: tail lights
You just need the tail lamp buckets for the tail lamps and reverse light, matching gaskets, lenses and rear light harness. Thats pretty much it. The harness from the cab to the rear frame SHOULD be the same.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 05-22-2012, 04:58 PM   #3
1moretoy
Re: tail lights
i do not have any of the wiring. do you know anyone that sells a rear kit.
Old 05-22-2012, 05:02 PM   #4
BMERDOC
BMERDOC's Avatar
Re: tail lights
Most of the big suppliers do but check the board first. As a matter of fact, I forget who but one of the guys just started advertising a butt load wiring harnesses. Check the parts board.
Nick Carter
Old 05-22-2012, 05:30 PM   #5
BMERDOC
BMERDOC's Avatar
Re: tail lights
Found it! HeavyMetalChevy...
http://67-72chevytrucks.com/vboard/s...d.php?t=525306
Nick Carter
Old 05-22-2012, 08:37 PM   #6
1moretoy
Re: tail lights
Thank you
Old 05-22-2012, 09:31 PM   #7
BMERDOC
BMERDOC's Avatar
Re: tail lights
Anytime! That what we're here for!
P.s. Don't forget the proper screws and speed clips if you don't have that stuff either!
Nick Carter
