What to do with my motor?
So we have diecided to drag race with the wifes 85 long bed. It has a 350 in it now. She would like to have a big block in it. My question is what should i do with current motor. I do not trust it at all. I was told it was rebuilt not too long ago but from what it looks like it was not. It does not make any noise or anything. Should i just pull it and put big block in when i get one or pull this one and open it up and see what it looks like and put it back in?
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
Dino burner
Re: What to do with my motor?
Happy wife = happy life
Yank the mouse and toss a rat in there! I'm always curious about engines, so if it was me, I'd tear down the small block once you've removed it from the truck. Have a look at it. Then you can decide if you want to keep it for another project or sell it. |
60-66 Nut
Do you or your wife have experience with drag racing?. If not, I would just start out with what you have. I don't think you necessarily need to pull the engine just yet. How is the oil pressure? Have you done a compression and a leak down test? That will tell you a bit about the condition of the engine. Once that is determined, you can choose a cam to upgrade to. You can also gradually upgrade things like intake manifold, carb, ignition, etc. while you are gaining some experience on the track. You don't have to go all out right at first.
Never race on a track befor no. The 350 has a cam in it now. Not sure how big. But i do have a friend that is gona ride with me a few time to tell me what i need to be doing. He has a massive mopar 330 that runs 9.90s. I guess i can run a leak down test on the motor. I really dont want to buy upgrades for it knowing it will be removed. One of the reasons i was gona remove it is it leaks oil. It has an edelbrock intake and holley carb and long tube headers.
Registered Truck Offender
[quote] But i do have a friend that is gona ride with me a few time to tell me what i need to be doing. He has a massive mopar 330 that runs 9.90s[quote]
You would be well advised to forget how fast someone else is, and remember there will ALWAYS be someone much faster. The quicker the car, the bigger the money pit it becomes. I am 1000% with the Captian ![]() Get some seat time in the 14's with what you have to learn the tree, the track and track etiquite. There is a LOT more to drag racing than just going balz-out fast.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
I know that there will always be someone faster then me. I just mentioned cause he knows what he is doing. I have been to lots of races and I don't want to be the idiot on the line. I need to redo the trans first thing cause it shifts amazingly slow between 1-2. So I may pull motor and clean it and seal it up. A th400 is a pretty good trans for a big block right?
#7 | |
It doesn't take a big block to make gobs of power and ET so your question is kind of misleading. eg. my 64 shoebox runs 9.13 @ 149,, normally aspirated, single carb smallblock. My racing partners 74 Nova runs 10.teens at 133 on a 9.5" slick at3 200 pounds with a Hughes Street-Strip TH350 ordered straight out of Summits cataloge and a Jeggs $350 converter,, also a n/a small block car.
Traction and torque looks for the weak link. If it's your trans, differential, u-joints, motor mounts ,, whatever the weak link... you will find it. Point I'm getting at is the Faster Faster Faster bug seems to be an affliction for which only poverty seems to be the cure. Be cautious how deep the waters before you jump in head first LOL Here's a long winded tutorial onthe first trip out onto the track... worth a read. Quote:
That is a ton of good info. Thanks for it. I do understand that a smallblock can and do go fast. We just want a big block cause we have had a smallblock. My burb has a ls motor and we want something different. I figure with a mild big block it will be pretty fast and we wont have to rev the crap out of it to go fast. So it should be better to drive around town. Not looking to go 10 flat on first pass but that is the end goal. Far far down the road.
I have actually ben to firebird race way in arizona. I went to uti 05-07. Loved arizone except the hole disapeaing car issues thay have. Wife 67 got broken in to 4 times and my bug was stole from our appartment. If that whould have not happend i would probaly still be there today.
