05-28-2012, 01:51 PM | #1 |
Which tank & driveline? LS powered '57
I'm figuring out which parts I'll need and have stalled out on the gas tank and the driveshaft.
I've considered using a stock replacement '57 gas tank and an external pump & filter setup. It should work just fine, but I don't know if I can do better for the money I'd spend. I figure I'll be $500 into the fuel system by the time I'm done, maybe more. $150 + shipping for tank, $2xx for pump, $80 for regulator For $500, can I do better? Under bed tank, in-tank pump, etc? What are people using for a driveshaft? I have the old shaft that ran from the SM420 to the 10-bolt. Just have a driveline shop cut it down & mate it to the 4L80E? Radiators... Anything from an OEM application that people have found? OEM parts I can buy wholesale. Custom is $$$. Thanks for any help! |
05-28-2012, 05:33 PM | #2 |
Re: Which tank & driveline? LS powered '57
I went with a Walbro 255 LPH external pump=$100-$120 on Ebay, 03 Corvette filter/regulator around $40.00 local auto parts store. I also put a pre-filter on it that I got for $10 to keep the pump clean. You should be able to use your original tank.
Kim |
05-28-2012, 09:55 PM | #3 |
I used an internal pump, I heard that an external buzzes pretty loudly? Not sure. Corvette filter/reg. Used a camaro tank from a 97? I think?
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold |
05-28-2012, 05:54 PM | #4 |
In tank pump is the way to go. I believe Chevy van or Blazer with FI tank will fit. do a search on this forum lots of info on this.
I'm using a tank from NoLimit.net I'm using a 2000 Camero Rad & Fan in my '57. Heres some pic's I took at a car show for my inspiration. |
05-28-2012, 11:52 PM | #5 |
OK, I'll see if I can get my hands on a Blazer tank.
If I use the original tank, though, I should be fine as long as I get an LS with no return system? |
05-29-2012, 10:01 AM | #6 |
tanksinc has everything you need and you can put it in any tank. you can even run return or returnless.
I suggest return style, since you will always have cool fuel at the rail and the possibility of vapor lock is nill. |
05-29-2012, 09:30 PM | #7 |
i have the same tank as g&r from no limit, except i have an internal pump.
i do not recommend this set up, as i have had to drop my tank to service the pump 4 times in 10,000 miles. once the pump went bad and 3 times for failure of the fuel line from pump to tank. i had written no limit many times for problems with this tank, he did replace the pump long after i bought one. but i have never had a explanation for the hose failures. the first hose failure was at zero miles. the tank is an excellent tank, i would use an external pump if i had to do it again. i used my stock drive shaft, but had to have it cut down to fit the 700r4 trans not sure how long your trans is, if it is the same as a 350 you can use the by changing the front yolk and u-joints the new u-joint have different sizes to fit the shaft and the yolk/rearend. i bought a desert cooler stock replacement from brothers, it was drop shipped from us radiator it has an extra core and trans cooler in it. looks good, works great. also have a spal fan and shroud
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-31-2012, 10:12 PM | #8 |
Looking at Ebay, I'm finding a 2002 Camaro LS-1 gas tank & pump for $130 shipped. "buy it now" is my new friend. 16.8 gallons, made of plastic, has an OEM pump designed for an LS engine. Sweet. Will add C-5 filter & cap off or use the return line as needed. Will figure out filler location when I get it under the truck. Have referenced multiple threads claiming this tank will fit, probably behind axle and under the bed.
Radiator wise, a used 2002 Camaro unit is, again, on Ebay for $100 shipped. Fans & shroud, another $100. Can't beat that. Credit card coming back out soon, I think... Apparently the lower mount takes a little work but the upper mount is caveman-easy. Hell, sounds good to me. I know a couple of sheet metal / fabricator guys in the area for help if needed. I have a 2 piece drive shaft w/ carrier bearing. The shaft was mated to a 10-spline SM420. It sounds like I'm better off finding a new shaft from somewhere, since I'd need a new yoke put on & a section cut out. Any good resources on different shaft input styles & lengths? |
06-01-2012, 07:27 AM | #9 |
Anybody know where you can get an air cleaner like the one on the blue showtruck in G&R's57GMC post?
06-01-2012, 07:34 AM | #10 |
Street and Performance, Mena, Arkansas has that filter, and a lot of other conversion parts, as well as a lot of knowledge about LS conversions. Their stuff is pricey!
06-01-2012, 09:04 AM | #11 |
I have a LSX 57 project also, I just installed a stock gm fuel pump module w/ an upgraded pump from a web based company called "ONLY FUEL PUMPS" $135.00, used the "VETTE WORKS" style rings to mount it into a new 1969 18 gal. mustang tank ($120.00), the tank mounts perfectly between the frame rails after moving the rear crossmember . hope this helps.
Learn to deal with reality, or reality will deal with you. |
06-01-2012, 02:17 PM | #12 |
Checked with Street and Performance on the air cleaner and they don't have a direct fit for my application. It's not cheap
06-01-2012, 02:30 PM | #13 |
Sorry, I assumed you were using a LS1 type engine that was pictured. S&P makes that air cleaner with the Mass Air Flow sensor built in (you can see the sensor/wires at the back of the filter where it bolts on to the throttle plate). What engine do you plan to use?
