06-01-2012, 10:12 AM | #1 |
another wood bed question
Do I install the wood before the bed goes on the truck or after?
06-01-2012, 11:28 AM | #2 |
Re: another wood bed question
Probably either one, my bed was on before the wood was ready. It would probably be easier if the bed was off the truck. The thing is dont rush, just take your time, it will take a while, mine took all day. Its much easier if 2 people are working on it (one to set the strips/wood with the bolts, and the other to be under the bed to tighten the bolts up.)
Just take your time and dont let it over whelm(sp?) you.
Mom, I think I may have broke something. My tires keep spinning and leaving black marks every where |
06-01-2012, 01:59 PM | #3 |
If you are hiding the bed to frame bolts afterwards, but trial fit with it off the truck. If the bed to frame bolts will be exposed, then you can do either. A second hand really helps.
06-01-2012, 03:27 PM | #4 |
I did mine a couple of weeks ago with the bed off. You have to get to the bottom to tighten up over 60 nuts with fender washers and lockwashers so it helps to have the bed at a convenient height with full access to the bottom. I supported mine on saw horses on each end so I could roll under it to install the nuts and washers. It would be more convenient to have a helper but it's not necessary. The bed is a lot heavier after you get the boards, strips, the cross members, and the bolts in, so be prepared for that. Mar-K's website has a set of instructions for wood replacement that I looked at before I started.
06-01-2012, 09:17 PM | #5 |
i hid my bed bolts so had to install the wood after.
bolted down the sills, laid the outer boards on the sills and set the box on the 2 outer boards.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
06-02-2012, 07:22 AM | #6 |
I did mine with the bed on the truck and my fuel tank out. Even still there were some bolts that were hard to get to. If you have the means (or help) to get it on the truck after it's assembled that would probably be the way to do it. It was just the wife and I and I didn't see her boosting her fair share of 500 (or so) pounds - or me for that matter, lol.
06-02-2012, 08:48 AM | #7 |
I put the wood in mine after the bed was installed. What a challenge getting the bolts tight in the strips. I ended up setting heavy blocks on each carriage bolt then crawling underneath to tighten them. Brand new paint plus long box truck made for plenty of opportunities to scratch or chip something during the process. But I didn't have any help so that was the only realistic option.
