Porterbuilt Body Drop ????
I saw Porterbuilt has body drops.Has anyone bought and installed one?? How is it? Would you Do it again?? I want to lower my 69' about 1 more inch all the way around.It all ready sits 4.5 in front and 6 in rear on coil and drop spindles..Should i go this route or not??Does anyone have any pics?? O yea how was the install??
Posted via Mobile Device |
67cheby
![]() Join Date: Sep 2008
Re: Porterbuilt Body Drop ????
I got it ....i Love the way it takes it on down !! PINCH FLAT ON THE GROUND , here are a few pics , any questions just give me a shout ! First getting rid of the stock mounts, and adding the new ones
67cheby
next ! notching the core support
67cheby
next....PINCH ON THE GROUND....and oh, dont forget SLOSH TUBZ !
![]() This is not low enough... KIDDING.. I will be buying this kit for mine.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074 Toys: 2014 Dodge Ram 1967 SHORTBED |
Square
nacho used one too. came out killer!
Squarebody Syndicate |
![]() Join Date: Jan 2012
nice kit
oh man, that looks killer......if only I could pull this off while the truck is blown apart
for the LS1 swap lol |
this is hot
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
If the truck is apart the kit is very simple to install. It didn't take me long to install on a bare frame. Well worth te money!!!!
LIFTED OR LOW THE ONLY WAY TO GO!!!! Check out my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=517346 Projects 56 Chevy pickup Porterbuilt FR/RR dropmembers |
67cheby; with all the other work you did to the suspension, did you need the body drop to fully lay out, or did you do it because maybe it will leave somethin' extra, not fully use the available drop without it. Plus it's kool.
I ask because I'm using Nate's dropmembers front and rear on my step, which is harder to lay out from what I hear. Just curious. If this doesn't make sense it may be because I've had a few margaritas while out in the garage and I make 'em strong! ![]() |
I love Broey's tag line.
#13 | |
67cheby
any pics or info on the box mounts? my truck just has the coils and was wanting to lower it some more but didnt want to change the suspension, plus the roads here are crap so i was thinking about this set up since im down to a bare frame right now
#15 | |
#16 | |
Core support (so it can set over the frame that extra 3/4") Cab at firewall to to floor pinch weld (really simple and not too involved) Cab floor for trailing arm xmember (more involved not terribly difficult) That's all the notching. ![]()
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#17 |
On mine I had to notch the floor for the trailing arm crossmember. On the front of the cab I had to cut the pinch weld just above the transmission because it won't let the cab come down to the cab mounts. The core support I haven't done yet but when I looked at it I figured I would have to notch it 3/4" plus what ever the thickness if your metal. The other thing that you will have to do is run a high hump trans cover and modify it for the 1" also. Hope this helps out.
#18 |
How much is the kit?
#19 |
$650 for the complete kit.
#20 |
67cheby.... Do your slosh tubz bolt up to all the factory mounting locations? It looked as if you have to trim your fenders.. Let me know because i might buy a set.. Are you going to be at GoodGuys in KC?
#21 |
67cheby
Yes they bolt in the factory locations you just have to trim the inner brace at the top to allow them to go all the way up
#22 |
Okay I guess there isnt a goodguys Kansas City this year.. Maybe the Des Moines Good guys
#23 |
67cheby
I don't think I will be able to make Des Moines, busting my butt trying to get Square Peg done for SEMA !
#24 | |
Square
#25 |
ulakovic22, hey i found some good pics of the notch in the cab for the trailing arm x-member. here is the link: http://67-72chevytrucks.com/vboard/s...358687&page=11 it starts at post #264. Very good images of the notch needed and if i am right this was fabbed by Nate at porterbuilt. I didnt want to copy the images on this thread without Nates consent.
