Old 06-06-2012, 11:48 PM   #1
Jargo
1963 3 speed transmission back to column
I am putting back my 63 3 speed transmission from the floor back to column and am wondering if anyone could answer the following?
1) Do I have the original transmission? The linkage on the transmission will not hook up the case number is GM9 3952645 it is a Saginaw.
2) Where can I find out what year this transmission was used? I have looked all over the net with no luck.
3)Where can I find linkage on the transmission to hook it back up?
Jargo is offline   Reply With Quote
Old 06-06-2012, 11:51 PM   #2
Jargo
Re: 1963 3 speed transmission back to column
3)Where can I find linkage on the transmission to hook it back up?[/QUOTE]
Old 06-07-2012, 12:28 AM   #3
jocko
jocko's Avatar
I doubt it is original. Is the number you posted off the side cover of the trans? Sounds like it is - and would indicate a late 60's-to-early 80's Sag 3-speed. You'd need a casting date from somewhere else on the trans to narrow down the date.
Best, maybe only, bet on the linkage is a junkyard. I would think you'd want to look for 3-speed linkage from a 60-66, all would be close to the same.
Also, ensure you actually have a 3-on the tree column before you get started. I'm assuming the truck USED to have a 3 ott, but if it didn't, then you're kinda back to square 1 - and need a steering column also.
Old 06-07-2012, 08:26 AM   #4
Jargo
The truck was originally a 3 spd column truck, it was my first truck, I bought it when I was 15 years old in 1980 from the original owner and found it last year it went through 3 different owners and it was mostly still stock other than the 3 spd was put in the floor. The owner who did that I cannot get in touch with, he may have changed the trans at that time. All the linkage from the column is still there it is where it attaches to the trans that is set up for a floor shifter.
I will send pictures. The bad thing is that I completely rebuilt the Sag transmission and I was hoping it was original
Old 06-07-2012, 09:21 AM   #5
Jargo
Here are pictures and there are cast numbers on the right side of the trans
they are 3880042 GM48 and 8825647 GM 31
Old 06-07-2012, 09:51 AM   #6
1963c-10
1963c-10's Avatar
Stock trans would have been a muncie mc318 3 speed
1964 Short bed trailer
Old 06-07-2012, 09:59 AM   #7
Jargo
Do you know what year this trans was built by the numbers?
Old 06-07-2012, 10:42 AM   #8
1963c-10
1963c-10's Avatar
Are you sure the main case isnt 3825647 and not 8825647?
Old 06-07-2012, 10:48 AM   #9
Jargo
I got a good light on it and it is 3925647 i was wrong
