Old 06-07-2012, 12:16 PM   #1
crr26@cox.net
crr26@cox.net's Avatar
engine decode
pulled this engine out of my 72 blazer, trying to see if it was original or what it came out of. engine id on front passenger side of motor. 18J173455 TIII5HF. PLEASE HELP?
crr26@cox.net is offline   Reply With Quote
Old 06-07-2012, 12:27 PM   #2
BMERDOC
BMERDOC's Avatar
Re: engine decode
The first number is a partial VIN. The second isn't making a lot of sense. Atr you sure its clear? The T would indicate that it was built in Tonawanda. You can find the casting number on the back, drivers side of the block just behind the cylinder head. The date code is back there too.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 06-07-2012, 03:39 PM   #3
crr26@cox.net
Re: engine decode
those are the numbers on it, i looked up the numbers on the back and it was very generic gave about 10 different setups it could have came in
Old 06-08-2012, 09:59 AM   #4
crr26@cox.net
Re: engine decode
ttt
Old 06-09-2012, 01:05 AM   #5
2fast55
2fast55's Avatar
Re: engine decode
Putting those numbers with the casting and date marks off the back of the block would help more, because the numbers here dont entirely make sense, but I'm thinking this is likely a 275hp 350 built 11/15/68 for a 69 chevelle, nova, or camaro. Maybe pull a valve cover and check the head casting numbers to really nail it down.
1972 Chevy K5 Blazer
1972 Chevy K20
1955 Chevy 3100
"If we knew what it was we were doing, it would not be called research, would it?"
- Albert Einstein
2fast55 is offline   Reply With Quote
