06-07-2012, 11:14 PM | #1 |
I can't believe it
I was just at the local garbage dump and found what looks like a 56 GMC or so 4x4. It is hard to tell because it is upside down and crumpled. Looks like its about a 3 ton. It looks like it has the original chevy v8 because their are no side motor mounts. Just the front ones beside the timing cover. I think its a 4 speed maybe 5 and still has the transfer case in it. I can't believe someone would send it to the dump. Looks like some company did a clean up because their are a couple of old 4x4 snow plows from the 50's as well as an old Dodge Power Wagon.
06-07-2012, 11:24 PM | #2 |
Re: I can't believe it
That's too bad. Can you snag some parts off of it or does the dump frown on that?
06-08-2012, 12:19 AM | #3 |
I can take anything I want. Nobody there take or leave anything you want at this place. I'm going to grab the T-case and linkage for sure.
06-08-2012, 12:32 AM | #4 |
If its NAPCO stuff grab it. Can be worth some $$$.
Unbelievable what some people wont give a second thought to trashing. Posted via Mobile Device |
06-08-2012, 12:43 AM | #5 |
Get the front axle, should have NAPCO cast into the axle tube. That and the drivelines, transfer case and frame attachment, shift linkage are the parts you need. I think the rear axles had lift blocks. fender trim were part of the package too, but a lot of guys did not use them. v8 motor mounts are reproduced so not a big deal. GMC grille and parking light lenses are not reproduced either, lenses are very valuable.
06-08-2012, 10:23 AM | #6 |
06-08-2012, 08:13 AM | #7 |
06-08-2012, 09:47 AM | #8 |
Down here the scrappers would have snagged all of that stuff an cut it up and hauled it off.
