06-09-2012, 05:14 AM | #1 |
Last opinions on 20" wheels...
After some long hard thinking i'm going to go with the Show Wheels "streeters". I need to know some thoughts on back spacing and fitment. I'm thinking 20X8.5 front with a backspace of 5.25" and a 20X10 rear with a backspace of 5.5". Front tires will be 255/35/20 and rear tires will be 275/35/20. Do you all think this looks ok? My truck is lowered 4 1/2" in the front so i'm worried about the fit in the front. Help me out, going to order these asap. Thanks, Joseph
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed 1966 C-10 lwb,factory A/C,Custom Cab 1954 Delray 2-door sedan [rat rod project]
06-09-2012, 03:36 PM | #2 |
Old member
Re: Last opinions on 20" wheels...
I used the Boss 338's and Love them.
8.5" up front and 10" out back. Back: Front:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
06-09-2012, 11:49 PM | #3 |
those wheels would look really clean on that truck.
-Mike- '94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s |
06-10-2012, 12:08 AM | #4 |
member "lakeanna" has these wheel with " toyo 295/40 on rear and 255/40 on the front"
check out his build thread here http://67-72chevytrucks.com/vboard/s...d.php?t=501870 the wheels specs/pics start on page seven, check it out. I think they look real nice. Some people whine about the lettering on them but It doesn't bother me I barely noticed it! looks great on his truck!!
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
06-10-2012, 05:06 AM | #5 | |
Old member
There the same ones who think you shouldn't cut your dash for the tunes you want! If I had know about these wheels before I bought my 338's I may have used them.
06-10-2012, 08:19 AM | #6 |
For the price I think they look great.
1971 chevy c10 ECE 4.5/6 dropped 1970 suburban ECE 4/6 Dropped 45K original miles so far 1948 Ford Sedan 1941 Dodge COE 1932 ford roadster the rest are normal drivers |
06-10-2012, 08:35 AM | #7 |
Great looking. As far as opinions...they will vary all over the place. The end result is - if you like 20" wheels. Go for it.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
06-10-2012, 11:44 AM | #8 | |
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
06-10-2012, 02:41 PM | #9 |
Thanks guys, i guess i should have been a little more specific on what "opinions" i was looking for. I'm 98% sure i'm buying these wheels, i too think they are a lot of bang for the buck. My main question is with the backspacing and tire sizes. My truck does sit very low in the front and the front tires do rub when i hit a decent size bump or turn my front wheels and go over some uneven ground. It's the outside edge of the tire that rubs on the inner fender, i think it's because the rallys have too much of a dish to them. I need everyones opinions on the front backspacing, and if there tires rub at all in the front. Also there are so many different tire sizes, just need to know which ones fit best. Thanks again for all the help guys, Joseph
06-11-2012, 12:22 AM | #10 |
What kind of front brakes? I dont know if the 71-72 front discs have a different track width than the 73-87 front brakes but with the 73-87 brakes 5.25-5.5 back space on a 20x8.5 front wheels should work depending on camber adjustment. 5.75 bs on a 20x10 in the rear should work if you have the factory width rear end.
06-11-2012, 02:48 AM | #11 |
Thanks. Keep the opinions coming! I'm going to call on them first thing this morning. Joseph
06-11-2012, 01:53 PM | #12 |
I would suggest looking at a 40 serries instead of the 35. I think you would enjoy a little more sidewall.
your ralleys are 0 offset so if they rub on the outside you will want more (+) offset. check out this site it makes compairing sizes easy http://www.rimsntires.com/specs.jsp Has anyone compaired ridlers 695 to the showwheels?
69 c10 lwb |
06-11-2012, 08:07 PM | #13 |
///Relaxed Atmosphere
i have the 35 series and have no rubbing at all but i think for a long bed a 35 will look to small go with the 40's.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
06-11-2012, 10:15 PM | #14 |
I think the 40 series will be a good choice, but it does come down to personal preference. I like a little more sidewall, and if the sizes are available in 40 series, I say go for it. Great looking truck by the way. The nice thing about the Showwheels, they bolt right up and no clearancing for the front hub.
Also, we are a Showwheels dealer, so let me know if we can help you out and get you some pricing. We have sold a few sets to the forum members here. Travis Posted via Mobile Device |
06-13-2012, 02:00 PM | #15 |
When it's time for me to buy new front tires, I think I'm going with a 40 series tire.
69 Fleetside Sunset Pearlescent 502/502 TH400 Rims - Coys Front -20x8.5 Rear - 20x14 Tires Front - 265-35-20, BFG KDW 2 Rear - 31-18-20, MICKEY THOMPSONS |
06-13-2012, 02:32 PM | #16 | |
And I agree with the others I would run 255/40 front and 295/40 on the rears.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
06-13-2012, 06:05 PM | #17 |
echoing what other's have said, opinions are dime a dozen, none worth a dime unless you agree.
I went different than all have suggested thus far. I like sidewall, I went with both wider and taller than most would suggest. No body on yet, and haven't ordered the rears, but I decided on 275/45/20 front and 295/45/20 rear. Nice and wide, and a bit staggered. BS from all the research I did will be just right, and shouldn't rub with these wheels. Not much in terms of reference points, but here is my fronts.
www.tomthetruck.blogspot.com <-- Aka build thread. |
11-08-2012, 11:22 PM | #18 |
Im runing 295/45/20 on the back of mine with no rubbing issues but i will be switching to a 305/35/20 this winter
05-08-2013, 09:50 PM | #19 |
If that's a Rottie in that picture, we have the same taste in trucks, truck color and dogs.
06-14-2012, 03:33 PM | #20 |
Thanks. Naw, I didn't think of doing a build thread. I'll take some more pictures this weekend.
06-13-2012, 02:20 PM | #21 |
Gawd what a beautiful color .. ZX12. WOW. I love it.
06-14-2012, 03:30 PM | #22 |
thanks alot.
06-13-2012, 06:17 PM | #23 |
I like those 45 series too. Is that the grey streeters? That is about the way I would like to go if I know it will not rub on truck. All stock now, but thinking of a 2.5 drop spindle and 4" drop in back.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
06-13-2012, 06:23 PM | #24 | |
I did lots of research and concluded from others on here I shouldn't, fingers crossed, have any rubbing issues with height, or width. Also, I find the name stamping to be less apparent in person than the photos. For one, in person the wheels are not the only focal point, they are a part of the package; plus they are down low and you are generally speaking, not hanging out face at wheel height. For the price, smoking deal. Only thing that would/might replace them in the future is a high end billet wheel when build is done and cash flow is better.
06-13-2012, 06:38 PM | #25 |
The backspace on the Streeters is good and you shouldn't have any rubbing issues. I have sold a few sets for the 67-72's and they have worked well. Just the narrower rearends on the earlier trucks require a spacer.
As for the name, I agree with Tmwoodall, and think the name is not that noticeable. It really disappears once the wheels are on the truck. Travis Posted via Mobile Device |
