![]() Join Date: Jul 2009
1961 GMC engine decision
Im working on restoring a 1963 Chevy 4x4 but the cab was beyond repaire and I bought a rust free 1961 GMC 2x4 with a 305 v6 and hydramatic that I plan to take the box and cab off and put on my 4x4. my question is what do you all think would be best, puting the 305 and hydramatic in and redo mounts or have a GMC with a sbc?
Location: I live in Honolulu but my truck is being restored by 4-5-6 Trucks in Kansas City
Re: 1961 GMC engine decision
305! Be original!
Posted via Mobile Device |
![]() Join Date: Feb 2011
V-6er!
MusicMan70 1961 GMC Suburban |
Who Me?
Those V-6's are cool!!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
I went to a lot of trouble to put a V6 back in my GMC. Somewhere along the line the original engine had been replaced with an I6. Keep the V6 - you'll be glad you did.
63chevy,
I have the exact same setup take a look see. Keep the Hydra-Matic, they are so rare, most folks think it a rumor ![]() http://rides.webshots.com/photo/2476...54402330doQPRY http://good-times.webshots.com/photo...54402330haALNv http://good-times.webshots.com/photo...54402330rzuLbc http://good-times.webshots.com/photo...54402330MBFGBN Keep the V-6, can't be many in the car club.
http://s1299.photobucket.com/user/jb...23904108567829 |
Thanks for the imput!! Im gonna go with the V6, even though the pickup wont be completly factory being the frame is 2 years newer and I dont belive the auto came in a 4x4? please correct me if im wrong! it will be all period correct GM parts
![]() Join Date: Jun 2007
The Hydramatic is very expensive to rebuild if it needs it, and if I had a 4x4 I wanted to use as a 4x4 I would not recommend putting the Hydramatic in. There is a reason why GM didn't like to install automatics in 4x4's and one of those reasons is because you can tear them up easy, and the other is that an Automatic trans is counter-productive to what a 4x4 is intended to be capable of. Not sure what happened to the manual trans out of the 63? if you still have it, that is a better option for a 4x4 that will be used a lot off road.
The V6 engine is also incredibly expensive to build compared to the simple SBC and parts availability is next to zero by comparison. If you can run the V6 as is and not have to rebuild it, then go for it, because it is a lot cooler and a perfect workhorse for a 4x4 but if you have to rebuild it to use it, I'd seriously think about that. All depends on what you are doing with the truck. Good luck! |
The pickup had a 3 speed when I bought it, that ended up in the scrap. I have a couple SM 420 trannys I could use. It will be seeing little to no off road driving and very little pulling of any kind. No matter what route I take for an engine I want to have an auto tranny, while manuals are cool i get enough shifting driving truck on the farm haha. I have considerd that, that the hydramatics aare expensive to rebuild, are they worth much to sell? I also have a 305 v6 in a 67 GMC 3/4 ton 4x4 and a 401 ina 62 GMC tag axel tandem farm truck, expcet we only use it for hauling sticks and branches now haha. But they seem to be very stout engines and run very smooth unfortunatly there are no performance parts and very little stock parts
![]() Join Date: Jan 2011
I have the same set up in my 61. I got a complete transmission master rebuild kit for $325, though I don’t know if that’s a lot compared to a turbo 350, or 700R4. The thing with the 61 Hydra-Matic is that there are no cooling lines you have to run (if it’s a 61 cast iron case) Not that it’s a big deal but it something. The engines are very tough and run like butter, very smooth and quiet, lots of torque. They just don’t want to be run at high RPM for long periods. The trans shifts a little hard though if you put your foot in it, with low gears. I have 410 posi in my truck. If you have it and it runs put it in now, if it breaks later you can either swap it out or if you like it rebuild or repair it then. As far as cost goes, I don’t think anything can beat a small block for building.
1961 GMC. Start date 1/20/2011 Past projects: 1958 Fleetliner 14ft Runabout 1966 Caprice 2dr 1970 VW Squareback |
305 with a hydramatic would be a work horse. it would do whatever that you wanted to ask of it. you can get o/h kits for that hydramatic if needed
ron |
![]() Join Date: May 2012
is that the same trans. that olds. called the slim jim back in 1963? does any one know...
no it is the old cast iron hydramatic used in caddilac ,olds and others to 56 and in gmc trucks from 54-62
ron |
padresag: i was not sure, the slim jim was a funny looking one also, thought that it might be the same...my mom had an olds. 88 back in 1963, it had a slim jim in it....thanks for the reply ...
#15 | |
![]() By rondavid at 2009-11-22 ron |
